Author Topic: Olson sport/progressive springs?  (Read 19513 times)
harleydan
« on: December 21, 2005, 12:33:39 »
I talked to John Olson about upgrading my springs on my car (1970 280SL).  John recommended his sport springs in the front and his progressive springs in the back.  Most if not all of the dialogue that I read in this forum have used his progressive springs all around.  Has anyone used this combination (John Olson sport springs in front with his progressive spring in back), or have an opinion in how well this particualr combination will work, or should I go progressive springs all around?
Re: Olson sport/progressive springs?
« Reply #1 on: December 21, 2005, 14:57:48 »
I am glad some one brought up the John Olson spring again to this forum. this has been an on going problem to get the height right for front and rear. I am glad to see The video was posted with Jim vilers from the 190SL group.
I think the mechanic who I used to install the progressive rate springs took me to the cleaners and did not due a good job. Tis is an on going project that I hope I can get fixed soon.
« Last Edit: January 31, 2007, 14:10:52 by Bob G »
« Reply #2 on: December 21, 2005, 16:01:09 »
I would go with John's suggestions - he is very knowledgeable about this subject and no doubt has good reasons for his recommendation.
RBurg
« Reply #3 on: December 22, 2005, 17:09:34 »
Bob:
 Up date is very much appericated.  Where did you find the large sway bar?  Unable to find one over the standard 19mm. Did you have yours custom made? If so where and what was the cost.
Ron
71 280SL Tobacco "O GIGI"
97 E420 Silver Mist
JimVillers
  • USA, VA, Virginia Beach
« Reply #4 on: December 23, 2005, 13:01:51 »
Ron .... The stiffer sway bar is 30mm and is made by Cox Racing http://www.coxracingroup.com/.  I believe that they charge about $350 for the bar.  I got mine used from a member who thought that the ride was a little harsh.  I love it.  When combined with poly bushings, it greatly tightens the suspension during cornering.
I could not find the item from their home page but here is a link to the sway bar:
http://www.coxracingroup.com/CART.ASP?whichpage=12&mode=price&item=161
It may or may not still be available.
Jim Villers
« Last Edit: December 23, 2005, 13:33:35 by JimVillers »
Jim Villers
harleydan
« Reply #5 on: December 23, 2005, 19:47:06 »
Jim,
About 2 months ago, I called Andrew of Cox Racing and inquired about the 30MM sway bar.  Unfortunatley, he does not sale that item anymore.  Maybe if there is a group interest, he would reconsider.
Arjun
« Reply #6 on: December 24, 2005, 18:15:09 »
Pls count me in for the sway bar.
Thank you,
1967 250SL 5-Speed
harleydan
« Reply #7 on: December 27, 2005, 19:05:52 »
I called Andrew at Cox Racingroup again   I asked him if there was a group order for the 30mm front sway bar for the Mercedes W113 would he reconsider making some more.  Andrew said if he had a order of at least ten (10) sway bars he would have them made and charge $350 a piece.  Any takers?
I have a bigger 230SL front sway bar coming hopefully soon for my 280SL so I probably at this time will not opt to get the 30mm Cox sway bar, unless the 30mm sway bar is significantly better than the sway bar that comes off the 230SL.
RBurg
« Reply #8 on: December 27, 2005, 20:06:41 »
Dear Harleydan: If I may ask - who are you ordering your 30mm sway bar
from?
I would be interested in the 30mm bar from cox.
Ron
97 E420 Silver Mist
harleydan
« Reply #9 on: December 27, 2005, 21:22:25 »
Ron,
The 30mm front sway bar would come from Cox Racingroup.  It is from the same company that made the 30mm sway bar as mentioned in the earlier forums.  So far there are only two people (Ron and Arjun) who have indicated that they would want to be part of the group order (of at least 10) to get the 30mm sway bar.  Any others?  There needs to be at least 10.  I am only facilitating this order to assist those who want this particular sway bar for their W113.
« Reply #10 on: December 30, 2005, 16:50:38 »
I e-mailed cox racing on knowing about installation of the 30MM front sway bar. No Response.  Now I read here their is a chance of Cox racing making a limited number of front sway bars. Before I committ I would like to fine out more from some of the group who have instaleed this sway bar.
1987 Ford Mustang LX 5.0
1968 280SL
1992 300-E Sport line
« Last Edit: January 31, 2007, 14:06:12 by Bob G »
Kenneth Gear
  • USA, VA, Fairfax Station
« Reply #11 on: December 30, 2005, 20:24:22 »
My car had the cox 30mm sway bar installed when I bought it and I like it.  If you are ever in DC, let me know you're welcome to drive it.
Ken G
1971 280 SL
Silver/red
Ken G
1971 280 SL Silver/red
« Reply #12 on: January 01, 2006, 12:25:12 »
Dan,
Can you describe the differences between the standard MB 230SL sway bar and the Cox Racinggroup 30mm sway bar?
At some point I will need to replace all the rubber and the shocks in my 230SL and that would be the time to swap out the sway bar.
harleydan
« Reply #13 on: January 02, 2006, 18:43:45 »
Rodd,
I am not an expert on the difference between the two front sway bars.  I do not even have either one of them since I have the smaller sway bar from the 280SL.  But for what is it worth....the Cox sway bar is 8-9mm bigger than the 230SL one.  A larger sway bar provides more rigidity and tightens the suspension on turns; however, there is a possibility that the ride may be a bit harsh for some.
Kenneth Gear
« Reply #14 on: January 03, 2006, 06:46:48 »
I would just add that the larger sway bar fits just like the original -- no modification necessary.
Ken G
1971 280 SL
Silver/red
Ken G
harleydan
« Reply #15 on: January 31, 2007, 08:21:50 »
I finally got around to having the suspension fully rebuilted.....new custom John Olson springs, new Bilstein shocks, new lower and upper control arm kits, larger sway bar (from 230SL), new sway bar mounts, king pin kit, new rear spring pad bushings, new subframe mounts, new braided brake lines, and new ceramic brake pads.   What a difference!  The car handles and feels great and tight based on my initial impressions while driving it home.  However, due to the recent road condition in the Colorado area, I really did not have a chance to really test it out.  Can't wait until the road conditions improve.
I soon might change my current Michelin mud and snow rated tires to a fair weather high speed tire.
My only negatively is that the front end is about 1.5 inches higher and the rear end is 1.0 inches higher than I wanted...I like the looks of a lower profile with the front end being just a tad lower than the back.  The front springs pads were changed out to the lowest possible.  So one option is to cut the springs but I really do not want to do that to my custom springs.  Any suggestions?
Cheers,
Danny
1970 280SL silver Euro 4 speed
« Reply #16 on: January 31, 2007, 10:51:55 »
I finally got around to having the suspension fully rebuilted.....new custom John Olson springs,....
Danny,
Hi.  Were these truly "custom", as you specified the spring characteristics, or are they what Olsen sells for all 280SL customers?  If they're the typical Olsen progressive rate springs, maybe he can have his spring source make some really custom springs for you and you can return the ones you have.  He can sell those to the next guy.
Dick M
« Reply #17 on: January 31, 2007, 11:33:18 »
Take a look at Jim Villers video on Shocks and Springs
http://video.google.com/videosearch?q=jim+villers&hl=en
TR
« Reply #18 on: January 31, 2007, 19:17:38 »
Dick -- That is a terrific video.  Thanks to both you and Jim for doing it, and for posting the link.  I've forwarded the link to my mechanical guy.  Even though all of the suspension was recently redone I think we'll now do a little bit of additional tweaking & tuning.
Trust all is well there in beautiful Nevada City!
Tom in Boise
Dick M
« Reply #19 on: February 02, 2007, 03:20:51 »
Tom...
Thanks.. Jim's video has had about 750 hits.  The Blacklick Tech Session linked from our club home page has had over 2200 hits and 30 downloads (according to Google) ...royalties are not that great however.
I'm surprised that anything remains to "tweak" on your car.
All is good here in Nevada City... come for spring visit.
Dick M
Raymond
  • USA, FL, Jacksonville
    • GemstoneMediaInc.com
« Reply #20 on: February 17, 2007, 16:13:09 »
I bought springs from Coil Spring Specialties in St. Mary's Kansas.  20% linear front and progressive to 20% in the rear.  Under $400 for the set.  My front was almost two inches too high with the thinnest pads.  I cut about 2-1/2 linear inches off of the spring coils and dropped the height a full inch.  I am going to go back and take another 1-1/2 off the springs when I get a chance.
On the rear, I used progressive springs.  They were about an inch too high.  I cut two linear inches off the bottom of the coil and the ride height came down to perfect.
I put Koni Classic shocks on all four courners.  The rear are perfect with the settings from Jim Viller's video.  The front are too stiff with the linear springs.  When I cut the front, I'll back off the shock stiffness a half a turn and I think it will be just what I wanted.
'68 280SL 4-spd Coupe
« Reply #21 on: February 17, 2007, 17:59:17 »
Does anyone have a good suspension alignment shop or mechanic in Los Angeles, California who knows the suspension on our cars. I have not been able to get my ride height correct since I purchased the John Olson springs and want to get a person who can correctly dial it in and fix the problem.
Front suspension bushing are fine replaced swaybar bushing front. Rear has all new bushing and I am running 185/ TR 14 rainforce michelins new. on factory steel rims.
1968 280SL
bobgeco@cs.com
310-839-8337
« Last Edit: February 17, 2007, 18:05:26 by Bob G »
harleydan
« Reply #22 on: February 17, 2007, 22:37:12 »
Bob G...did you try changing to thicker or thinner spring pads to get the clearances that you want?  In addition, I have heard of people grinding the spring pads to get them even closer to the clearance wanted because the pads only come in a few sizes.
Raymond...when I look at the springs - both stock and John Olson, I noticed that the coils are much closer at the ends as compared to the middle.  When you cut/shorten your springs, how did you make them fix/sit properly in the spring pads?  How do you know how much to cut off the springs in order to get the required drop?  Unfortunatley, I have non-adjustable relatively new Bilsteins shocks on mine so I can not compensate for whatever changes I make to the John Olson springs.  Nevertheless, I would not mind a firmer ride if I can get the look (a bit lower) and handling (better in turns and being more level upon braking/acceleration).
Cheers,
Danny
Raymond
« Reply #23 on: February 18, 2007, 06:58:58 »
Danny,
  The front springs on the bottom end don't flatten out, the coil just stops.  That's the bottom where the A arm it sits in is shaped to hold it.  The pad at the top is notched to sit at the end of the coil, so it can rotate anywhere and the pad is still flat against the top.
The rear springs are progressive and the coils get progressively closer together toward the top.  Therefore cutting the bottom is the same as for the front.
How much to cut is trial and error.  I'd rather cut too little and have to do it again, than cut too much.  Thanks to some great advice from Jim Villers, I found that cutting very little off of the linear measure of the steel (not the height of the coil) makes a big difference in ride height.  That's why I did two inches from the end of the steel as the first experiment.  It was perfect for the back.  If I had cut more, I could have made the difference with thicker pads, or the boiler washer that Jim used on his cars.
The rear springs are no problem. But because the front springs are so much harder to do, I will next do only one and put the car back on the gound to see how close I've gotten.  Then if I'm too conservative in the cut, I'll only have one to do over and can do the second side to match.
It isn't complicated but you need a way to get the car high enough, a jack that can ease off and compress the A arm, and a second person.  You also,really should study the Blacklick video of Jim Villers explaining the method. If you can't download it, let me know.
The braking nosedive and cornering improvements are terrific!
harleydan
« Reply #24 on: February 18, 2007, 08:41:51 »
Ray,
Thanks for the info...
And if I did switch to Koni shocks, which specific ones do you use/recommend?  Can the Konis be adjusted while mounted on the car or do they have to be taken off (partly or whole)?
Cheers,
Danny
