Author Topic: Automatic Tranny help  (Read 3491 times)
« on: December 30, 2005, 15:53:02 »
Took My 69 280SL Auto Tranny out today.  Was cruising along fine when all of the sudden it did two things at the same time..
[:(!]The tranny popped out of gear, and the Speedometer stopped working.
Pulled off, did'nt see any thing damage..
 :?: Now it shifts up into 3rd, but won't go into 4th. and Speedo still not working..
Any help??
Jeff Abbott
1969 280sl
2005 Acura TL
2002 Jeep GC Ltd.
1976 MG Midget
Re: Automatic Tranny help
« Reply #1 on: December 30, 2005, 17:55:27 »
Hello Jeff,
The fact that your speedometer quit working probably means something may have happened in the rear section of the transmission where the governor, and rear pump are located. The speedometer drive gear is also located here.
Drain the fluid and remove the transmission oil pan and see if you find any debris or parts in the pan to start with.
« Last Edit: December 30, 2005, 17:57:02 by ja17 »
merrill
« Reply #2 on: December 30, 2005, 17:56:30 »
Jeff,
the speedo cable connects to the tranny
maybe someone else will have more info for you
Matt
Austin Tx
66 230 sl - "white"
78 300 D - Blue
98 C230
« Reply #3 on: January 01, 2006, 07:28:25 »
Thanks for the help..
I will get back with you to let you know what I find.
Jeff Abbott
1969 280sl
2005 Acura TL
2002 Jeep GC Ltd.
1976 MG Midget
