Author Topic: 230 SL Wiper Linkage ?  (Read 5480 times)
patm
« on: January 09, 2006, 19:37:40 »
Is there any easy way to get at the wiper linkage? It seems to be frozen up on the right side. Do you have to take the dash out? Thanks Alot, Pat.
Pat McCusker
Re: 230 SL Wiper Linkage ?
« Reply #1 on: January 10, 2006, 08:11:28 »
Hi Pat,
The wiper linkage is fitted to a motor located behind the glove box.  The motor can be removed by unbolting the linkage and then unbolting the motor from the engine compartment.  The linkage is connected to the motor arm by a single(10m?)bolt.  It may be accessable without removing the glovebox but I'm not sure.
As the motor arm spins the wiper linkage pivots in a couple of places under the dash.  If the motor isn't frozen I don't think your problem lies in the area.  In addition to the under dash wiper pivot pins the linkage spins CW and CCW via the wiper shafts which extend through bushings in the body below the windshield.  More than likely this is the area where the binding has occurred.  I suggest you remove the wiper arms and spray penetrating oil in the wiper shaft/bushing area to see if you can free up the binding.  The entire wiper linkage assembly can be removed if you take the gauges and other under dash components out.  It's a pain to do. After the penetrating oil has had some time to work you should be able to move the wiper linkage from below the dash by hand or via the wiper arm on the shaft outside the body.
Tom230sl
« Reply #2 on: January 10, 2006, 10:35:12 »
More than likely it is the liinkage,
pics for reference...
Download Attachment: P1010063.JPG
38.31 KB
Download Attachment: P1010068.JPG
26.76 KB
Download Attachment: PB180023.JPG
34.67 KB
« Last Edit: January 10, 2006, 10:41:08 by Tom230sl »
erickmarciano
  • Canada, Quebec, montreal
« Reply #3 on: January 10, 2006, 10:39:17 »
Tom Is the heat padding on your floor the same patern as the firewall pad / can I be used ?
thanks
1971 280sl
1962 VW
1954 Allstate vespa
1958 gs150 vespa
1962 gs160 vespa
1994 E500 W124
1971 280sl
1989 Porsche 930 coupe
1988 e30 m3
2001 ducati mh900
2006 ps1000
1962 Vespa GS160
Tom230sl
« Reply #4 on: January 10, 2006, 10:42:20 »
thanks
1971 280sl
1962 VW
1954 Allstate vespa
1958 gs150 vespa
1962 gs160 vespa
yes
« Reply #5 on: January 10, 2006, 11:05:54 »
Tom, Nice pics!
It's very possible these joints are the ones.  However they are not exposed to the elements as are the wiper shafts which protrude through the body.  These bushings and shafts are seldom lubricated and often corroded with rust.  Atleast that was the case with my car.
patm
« Reply #6 on: January 10, 2006, 16:55:32 »
Thank you Tom and Jeff. This is teriffic information that should make the job a lot easier. And I agree the pictures are  great. I cant thank you enough. Pat.
Pat McCusker
