Become a
Full Member
Emergency Contact List
General Discussion
engine idle
Topic: engine idle (Read 3055 times)
engine idle
January 18, 2006, 21:21:28 »
My engine idle keeps rising when I come to a stop. I hit the pedel & sometimes the ldle goes down,sometimes it doesn't. The thing is...my adjustment on the "throttle body" for the large butterfly is backed all the way off. Any ideas?
Full Member
Platinum
USA, CA, Cedar Ridge
Re: engine idle
January 18, 2006, 22:16:37 »
Hey Gator. Glad to see your name over here. It sounds like it could be a leak in your braking system -- I think others here have had similar situations. Do a search for things like "idle, brakes, vacuum" and you'll get some ideas...
Full Member
Platinum
USA, OH, Canal Winchester
Pagoda SL Group: 20+ years and going strong!
Re: engine idle
Reply #2 on:
January 18, 2006, 22:20:02 »
John,
Hello and welcome to the Group!
Use the Search tool and look for "venturi". That's a common name for the intake manifold flap unit. You'll learn that it needs to be set right and that it's incorrectly used as an idle adjustment. Here's one good Search result:
http://index.php?topic=1412
Does your idle rise if you have the car out of gear (manual) or in park (auto) and you step hard on the brake pedal? I'm wondering if you have a vacuum leak in the brake system.
http://index.php?topic=4214
,leak
http://index.php?topic=3101
,leak
1966 230SL, Euro, Auto, Leather, both tops
Full Member
Platinum
USA, OH, Blacklick
Re: engine idle
Reply #3 on:
January 18, 2006, 22:53:40 »
Hello John and welcome,
If you have a USA delivery 280SL the venturi also has a vacumme idle control dashpot (governor) which regulates idle speed also. If You have this let us know and we can advise.
Re: engine idle
Reply #4 on:
January 19, 2006, 22:30:44 »
Yeah, sorry! My car is a 66' 230 & it is a grey car, not U.S. but european. 4 speed. If it is the brake system, what might be the problem!
Associate Member
Platinum
Canada, ON, Port Lambton
Re: engine idle
Reply #5 on:
January 19, 2006, 23:10:43 »
Gator??? ( we know each other )
Could be sticking flyweights inside of the distributor. Let the engine idle once it's hot and check idle speed. Turn off engine and then re-start without touching the gas pedal. If the idle speed is a lot lower repeat this test again. If it's consistantly lower try driving the car around then let it go back to an idle again. If it's now at a higher idle speed or the speed changes all the time ( sometimes high , sometimes low ) it's likely a sticky distributor.
Throttle linkage can also affect idle speed. You do have an oil can?
1966 230SL 5 speed, LSD, header pipes, 300SE distributor, ported, polished and balanced, AKA ''The Red Rocket ''
1970 3.5 Coupe
1961 190SL
1985 300CD Turbo Coupe
1981 300SD
2013 GMC Sierra
1965 230SL
General Discussion
engine idle
