Author Topic: gas mileage  (Read 19519 times)
Re: gas mileage
« Reply #25 on: March 14, 2006, 20:53:50 »
As the other respondants have indicated, if you don't want to get too technical, it is safer to stay with premium fuel. For myself, I don't, as I have a keen ear for engine knock. The iso octane difference does not change the power or energy output or mileage between regular and high test, unless there is a knock. And knocking or pre-ignition, a shock wave, can be brought on by high engine temperatures, high ambient temperature, changes in ambient humidity, ignition timing, carbon buildup in your engine, etc. I giv emy engine about as much timing advance as she'll take, then back it off a few degrees, and drive with regular, getting about 17 MPG and great performance. Mixture is biased rich as too lean is far worse. With Suzy's car, she should stay safe with high test, but I would check her car's rear end ratio, and get a printout of the exhaust emissions and track ignition on a scope. Her car may have bad points or wrong dwell, or if electronic ignition, have some peak secondary voltage problem (wrong coil for electronic ignition?). Overly rich mixture will sure kill mileage, and needs a real expert to adjust.
Joe Bango
Re: gas mileage
« Reply #26 on: March 15, 2006, 08:25:45 »
Quote
Originally posted by Benz Dr.
Gee, I only get 10 km per liter.........or 22.5 MPG ( USG )
 I believe you will find the USG conversion for 10 km/per litre would be 23.9 mpg ..
Re: gas mileage
« Reply #27 on: March 17, 2006, 00:00:36 »
Is that normal mileage for a 250SL engine? I based my figures on 4.56 liters in the Imperial gallon. I think there's 3.8 in a US gallon. 100 km is about 62 miles.  I use 10 liters in 100km.
10 liters is 2.63 USG
10 liters is  2.19 IMPG
62 miles  divided by 2.19 = 28.3 MPG IMP
62 miles  divided by 2.63 = 23.5 MPG US
Although math was never my best subject I think 28 miles per ( Imp ) gallon is prety good for any of these cars.
Re: gas mileage
« Reply #28 on: March 17, 2006, 08:43:43 »
<<62 miles divided by 2.63 = 23.5 MPG US
Although math was never my best >>
 Your math is fine, Doc.
 I think your first post was just a  typo [ 22.5 USG], as was my correction [23.9]
 23.52 is the correct MPG/US ..and that is great for a 113, that's for sure..
Re: gas mileage
« Reply #29 on: March 18, 2006, 13:14:08 »
My car is a 5 speed so I'm sure that helps out a bit.
 I also have about 180 PSI compression, new valves, rockers, heat wrapped headers,hot 230SL camshaft tuned to euro 280 specs, dual point dist from a 300 SE, ported and polished cylinder head tuned on a flow bench and a number of other inventionsI won't tell you about.
           It is the ''Red Rocket''
 Maybe I'll get to drive it this year........
