Author Topic: ALTITUDE ADJUSTMENT  (Read 3107 times)
keesing
ALTITUDE ADJUSTMENT
« on: February 16, 2006, 14:35:36 »
My '67 250SL will be transported from sea level to 7,500 ft above sea level...
1st: Will it start?
#2: If it does start, will it cause any problems driving it about 75 miles before I adjust it or is that just asking for problems?
#3: Is the correct adjustment simply on the fuel injector and air adj screw - or is there more to it??
 :mrgreen:
I knew it doesn't have carbs... :?
« Last Edit: February 16, 2006, 15:09:25 by keesing »
Re: ALTITUDE ADJUSTMENT
« Reply #1 on: February 16, 2006, 15:02:41 »
Can't say for that high -- but mine starts fine in Tahoe which is 6000 and Santa Barbara which is about 60. I bet if your car started at sea level, it will also start at 7500. It may run richer up there since the air is thinner. Our cars don't have a carburator -- but there are ways to adjust the mixture nonetheless. I'd be careful and research before doing too much. It is my understanding that the FI has a built-in mechanism (altitude compensator)that takes into consideration altitudes...
DavidAPease
  • USA, CA, Chico
« Reply #2 on: February 16, 2006, 15:42:56 »
I drove my 230SL across Monarch Pass in the Rockies last summer, an altitude of 11,300 feet.  No problem at all.  I believe that the altitude compensator in the FI system takes care of everything.
I certainly wouldn't expect to have to adjust anything as one drives up and down mountains.  As Chad said "it's a Mercedes".
-David Pease
'66 French 230SL
-David Pease
Chad
« Reply #3 on: February 16, 2006, 17:11:41 »
It will most likely start. Just fill it up and drive it up I-25 and figure everything out when you get home. There are several good Mercedes places in Santa Fe area. Find someone who knows it.
« Last Edit: February 16, 2006, 17:13:31 by Chad »
« Reply #4 on: February 16, 2006, 18:33:25 »
The altitude compensator is AKA the barometric pressure regulator if I am not mistaken. It's that big round canister thing sitting on top.
quote "I am always right. Only once I though I was wrong, and even then I was mistaken"
« Last Edit: February 16, 2006, 18:34:27 by cees klumper »
enochbell
« Reply #5 on: February 17, 2006, 10:08:47 »
Yes, the IP does auto-adjust for barometric pressure by moving the regulator along the rack at all throttle positions (not just at idle) when relative pressure is less than 1 atmosphere.  That, and the way the cone in the IP is mapped (it is milled in three dimensions but it is not concentric: rather, it is parabolic shaped, and how MB decided how to do this is a mystery to me) is one of the most amazing engineering feats, perhaps one of the real engineers on the board can give a quick tour.
g
