Author Topic: problem with brake booster  (Read 3689 times)
lurtch
  • USA, CA, Santa Rosa
  • " ICON 66 "
« on: March 02, 2006, 22:10:32 »
Hello to all - - If you please,  who  among us is knowledgable about the brake vacuume servo and the non-return valves?
All of a sudden I need an enormous amount of pedal pressure to get this thing stopped. No leaks are apparent, no squeal, no pedal vibrations - - all four corners have new or within tolerance calipers and  pads- - .  The Haynes manual is not difinititive about the non return valves.
Are these things simply a check valve? Do they need cleaning periodically?  My car may be unique and incorrect because of  inept tampering episodes by P.O.s.  There are TWO non-return valves in the line over from the manifold. Could this be a contributing factor? Do they clog in the open position? Is there another priority valve inside the diaphram chamber? Wouldn't a ruptured diaphram emit a noticable hiss?
Thank in advance - - - Larry
Larry Hemstreet  in  N. Cal.
1982  300TD-T (parted out)
1986  560SEC (totaled)
1991  300TE (gifted)
1998  E320 (sold)
2004  E320 wagon (gifted)
2008  CLK550 Cabriolet
Re: problem with brake booster
« Reply #1 on: March 02, 2006, 22:37:08 »
Larry,
There should only be one check valve in the line from the intake manifold to the booster.  You can simply take these out and test them, possibly with your breath??  I would think vacuum line would be cheap if you need a new length of line.
Does your engine RPM rise when applying the brake?  That's a test for air leakage.
What type SL do you have?
dldubois
  • USA, FL, Pembroke Pines
« Reply #2 on: March 02, 2006, 22:51:33 »
Another potential cause could be the rubber brake lines to the calipers.   Over time they tend to swell which could lead to this result.
I've owned two 280sls and have replaced on both.   One car had the brake lock up as a result and the other would engage the brakes.
Dana DuBois
1969 280sl auto
blue (906)
Corinth, TX
Dana DuBois
1969 280sl
Pembroke Pines, FL
Vince Canepa
« Reply #3 on: March 03, 2006, 06:46:15 »
The valve is a simple check valve.  It is there to trap some vacuum in the booster should the engine stop.  If it is working properly, after shutting off the engine you should be able to feel it in the pedal if you apply the brakes several times.  The pedal will "harden" as you deplete the vacuum.  When my original booster failed the symptom was similar to yours.  The brake hoses are another good tip, althought they should fail more gradually.
Vince Canepa
113.043-10-001543
568H Signal Red
116 Caviar MB-Tex
