Author Topic: does anyone know what "05" camshaft is?  (Read 3356 times)
erickmarciano
  • Canada, Quebec, montreal
« on: March 06, 2006, 17:03:24 »
thanks
Erick
1971 280sl
1962 VW
1954 Allstate vespa
1958 gs150 vespa
1962 gs160 vespa
1994 E500 W124
1971 280sl
1989 Porsche 930 coupe
1988 e30 m3
2001 ducati mh900
2006 ps1000
1962 Vespa GS160
Re: does anyone know what "05" camshaft is?
« Reply #1 on: March 06, 2006, 23:42:28 »
Hello Erick,
The "05" camshaft was used in the 280 series W114 sedans. It will work fine in an SL as long as the Main journals are the same diameter as your original cam otherwise you will need to switch these also.
It is not as "hot" as an SL camshaft so you would loose some HP. This camshaft was made with an "improved material" and replaced the "01" camshaft. The "11" and "86" were sedan camshafts which were a little "hotter" than the "05".  The "08" and "04" would be the worst sedan camshaft to use.
« Reply #2 on: March 07, 2006, 06:11:00 »
Do you guys know which camshaft was the same in both sedans and W113 cars of the era?
The same #11 or #86 was used in 250SLs and sedans of the era. The sedans were some of the finback 230S (W111), and the 250S, SE (W108).
These are a nice find since they are second hottest camshafts. The 230SL camshafts #76 and #84 and the early or euro cam for the 280SL #02 and #09 all had the longest "total valve open duration" (142 degrees) and yielded the best performance in their particular engine series.
erickmarciano
« Reply #3 on: March 07, 2006, 10:07:11 »
I just purchased a head with cam as a spare for the future since I think My late 280 head is rare and it came with the 05 cam .
thanks
Erick
1971 280sl
1962 VW
1954 Allstate vespa
1958 gs150 vespa
1962 gs160 vespa
1994 E500 W124
1971 280sl
1988 e30 m3
2001 ducati mh900
2006 ps1000
1962 Vespa GS160
« Reply #4 on: March 07, 2006, 12:37:01 »
Originally posted by erickmarciano
....I think My late 280 head is rare....
Why?
erickmarciano
« Reply #5 on: March 07, 2006, 12:42:30 »
I guess I used the wrong word <rare> . I just wanted a spare since it was only made for a few years .
1971 280sl
1962 VW
1954 Allstate vespa
1958 gs150 vespa
1962 gs160 vespa
1994 E500 W124
1971 280sl
1988 e30 m3
2001 ducati mh900
2006 ps1000
1962 Vespa GS160
« Reply #6 on: March 07, 2006, 17:33:16 »
Hello Erick,
It would work fine for a spare, you may loose a few horse power.
