Author Topic: FI Pump Thermostat  (Read 3206 times)
Raymond
  • USA, FL, Jacksonville
    • GemstoneMediaInc.com
FI Pump Thermostat
« on: March 11, 2006, 03:51:35 »
The replacement fuel injection pump thermostats have a larger brass base than the older thermostats with a rubber base.  The guide ring that the thermostat sits in has a 10mm hole and the new thermostats have a 13mm base.  My dealer diligently searched computer, classic center, and even microphiche but didn't find a part number listing for the guide ring.  (Unless it's called "Sealing Ring" and costs $60)
My inclination is to drill out the hole in the guide ring.  I have an old press drill, but no jig.  How precise does the hole have to be?  How easy is it to goof up?
'68 280SL 4-spd Coupe
Re: FI Pump Thermostat
« Reply #1 on: March 11, 2006, 05:36:36 »
Hello Ray,
I drilled mine out.
The hole doesn't have to be too much bigger than the black plastic of the new inj thermostat. After all it just needs to allow the thermostat to sit flat like the old one did.
The guide ring is soft metal.
JPMOSE
  • USA, DE, Harbeson
« Reply #2 on: March 11, 2006, 06:59:45 »
http://www.sl113.com/forums/index.php?topic=1386,
Best Regards,
J. P. Mose
1968 250SL
Best Regards,
J. P. Mose
1968 250SL
1970 280SE 3.5 Cabriolet
1987 560SL
