Author Topic: Spark Plugs  (Read 5094 times)
dwilli3038
Spark Plugs
« on: March 19, 2006, 15:24:39 »
I went to Auto Zone today and asked for Bosch W9DC plugs. I did not notice intil I go home but what they gave me was WR9DC. Do I need to return them or will these work?
Daryl
'64 230 SL
Serial # 508
Re: Spark Plugs
« Reply #1 on: March 19, 2006, 15:35:26 »
You do not want Resistor plugs..
 Some parts guys kill me........
mrfatboy
  • USA, CA, Rancho Santa Fe
    • Mrfatboy
Re: Spark Plugs
« Reply #2 on: March 19, 2006, 17:25:50 »
"do you want fries with that?"
sorry, i could not resist.
1969 280sl (Aug 1968 build)
Signal Red
4 Speed
Re: Spark Plugs
« Reply #3 on: March 19, 2006, 18:14:47 »
<<"do you want fries with that?"
 ....Perfect !!!!
 .. yeah, Fries and a 4 wire O2 sensor.
70chevelle
Re: Spark Plugs
« Reply #4 on: March 20, 2006, 09:34:07 »
My understanding of this situation,is that you need to remove (unscrew) the resistor from the top of the plug.  Maybe some of the veteran mechanics can chime in this?
70 Chevelle 13.7 @ 99.7
70 280 SL Silver/Black top
05 C230 Kompressor
03 Dodge Durango SLT
Raymond
  • USA, FL, Jacksonville
    • GemstoneMediaInc.com
Re: Spark Plugs
« Reply #5 on: March 20, 2006, 16:54:34 »
Yes, return those plugs.  You need all the fire you can get from the business end of the plug.  Bosch still makes a W9DC without the resistor.  The Autozones here in North Florida do not carry them and they don't show up in their computer system.  They do carry an NGK equivalent and I used them for a short time with seemingly good results.  You'll need to call around to other stores to find the Bosch plugs but they can be found, and can be bought via the internet.
'68 280SL 4-spd Coupe
mrfatboy
    • Mrfatboy
Re: Spark Plugs
« Reply #6 on: March 20, 2006, 18:28:49 »
Napa Auto parts carries them.
Signal Red
4 Speed
Re: Spark Plugs
« Reply #7 on: March 20, 2006, 22:50:58 »
I can get you all the Bosch plugs you want, 10 to a box.
The small screw on piece on the top of the spark plug is NOT a resistor, you either leave it on or take it off depending on the plug wire set you use.
dwilli3038
Re: Spark Plugs
« Reply #8 on: March 26, 2006, 11:49:44 »
"Fries with that" is right!! Since Jean needed to go right by AutoZone she said she would return them. She told the guy that I wanted W9 DC not WR 9DC. He said there is no such plug and suggested she bring a old one in and he would be glad to compare with other plugs to fing one that LOOKS the SAME!!!! She got my money back and I stoped at the local NAPA who had the W9DC s that I wanted.
Daryl
'64 230 SL
Serial # 508
