Author Topic: - - Symptoms of a failing brake booster?  (Read 2892 times)
lurtch
  • USA, CA, Santa Rosa
  • " ICON 66 "
« on: March 24, 2006, 18:23:53 »
Hello All - -
 Lately I have noticed a significant increase in the pedal pressure required to make a "normal  braking rate"  stop. The pedal feel is very firm , not at all spongy . Hoses are new, wheel cylinders are new, no fluid loss.
Depressing, then releasing,  the brake pedal at a stop sign will raise this to 1400 RPM and then drop it to 900 RPM's when I lift my foot..  I realize that some of this increase is normal because of the engine vacuum draw-down required to actuate the booster.
However the RPM's do not wind back down like they should if I maintain pedal pressure. Only by releasing pedal pressure do the RPM's  drop off.
The hose over to the booster is all new and a bench check of the check-valve seems to  be fine. Connection clamps have all been upgraded and  have been retightened.
Could this problem indicate some air  by-passing  around or through the diaphram?
I have seen mention  on this site that these  boosters are known to be very durable and trouble-free. However, this particular SL was slumbering in a Texas warehouse for more than five years before returning to service very recently. I suspect the old rubber is beginning to deteriorate and is gaining some porosity.
- - -Ideas from someone who has been here?
Thanks in advance,  Larry in CA
Larry Hemstreet  in  N. Cal.
1982  300TD-T (parted out)
1986  560SEC (totaled)
1991  300TE (gifted)
1998  E320 (sold)
2004  E320 wagon (gifted)
2008  CLK550 Cabriolet
Re: - - Symptoms of a failing brake booster?
« Reply #1 on: March 28, 2006, 21:06:44 »
Yes
Larry,
My 1966 230SL still had it's factory original booster when I bought the car in 2000.  It needed replaced, so I don't know how many years it really lasted.  The car still stopped, but it stopped MUCH better after the booster replacement.
