Author Topic: part number question  (Read 3582 times)
merrill
« on: March 26, 2006, 18:33:55 »
I was going thru the old recepts my dad had for my 66 230.
there is a recept for
113 270 01 01 88 Gear box $1,989.  from 8/97
I am wondering if he had a tranny put in?  the cost is low, maybe it is a used item?
in 200 there is a recept for a tune up that indicates metal shavings in the tranny pan.
I am just about ready to just pull the tranny and have it rebuilt out of frustration due to lack of info.
matt
Matt
Austin Tx
66 230 sl - "white"
78 300 D - Blue
98 C230
68_white
  • USA, TX, Houston
Re: part number question
« Reply #1 on: March 26, 2006, 19:43:51 »
I would not do that.
Have someone reputable check the transmission out for proper operation.
I had very frustrating experiences with mine. Noises, leaks, skipping gears.
I took it to two different shops to get the work done right.
HARRY
68_WHITE
HARRY
1970 280SL RED
2002 E430 SILVER
1996 911 BLUE
« Reply #2 on: March 26, 2006, 22:41:05 »
Hello Matt,
What issues are you having with your transmission?
merrill
« Reply #3 on: March 27, 2006, 07:00:00 »
Joe,
no real issues,  sometimes the shifts are rough, especially when coming to a stop,
also, the shif plate inside the car gets hot, well really more very warm than hot.
I am more concerned with the metal shavings found in the tranny oil pan the last time the oil was changed.
matt
Matt
Austin Tx
66 230 sl - "white"
78 300 D - Blue
98 C230
merrill
« Reply #4 on: March 28, 2006, 06:46:02 »
heard back from gernold at sl tech on this.
the part is a rebuilt tranny that mb had on sale at the time.
I guess this is good news, however, I am still concerned about the service note regarding the metal shavings in the tranny filter pan.
Matt
Austin Tx
66 230 sl - "white"
78 300 D - Blue
98 C230
« Reply #5 on: March 30, 2006, 07:24:25 »
Originally posted by merrill
Joe,
no real issues,  sometimes the shifts are rough, especially when coming to a stop....
Matt,
This is often fixed by properly adjusting the flap in the venturi.  My car was slamming those down shifts until I was at Joe Alexander's one day.  He spent about 90 seconds adjusting that flap for proper closure and the hard down shifts were gone!
« Last Edit: March 30, 2006, 07:24:58 by rwmastel »
merrill
« Reply #6 on: April 02, 2006, 07:36:30 »
Rodd,
pulled the venturi post and checked the venturi setting on my car.
well, the set screw was backed out so far that it was not engaging the linkage at all.
I guess I will find the linkage adjustment post and check the linkages
matt
Matt
Austin Tx
66 230 sl - "white"
78 300 D - Blue
98 C230
« Reply #7 on: April 04, 2006, 16:06:39 »
Rodd,
well, the set screw was backed out so far that it was not engaging the linkage at all.  I guess I will find the linkage adjustment post and check the linkages.
Any luck?
merrill
« Reply #8 on: April 04, 2006, 18:53:28 »
rodd,
I have the print outs for the linkage adjustment, I still have yet to double check the linkage settings.
I will reply with the findings once I am done
thanks
matt
Matt
Austin Tx
66 230 sl - "white"
78 300 D - Blue
98 C230
