Jeff,
Thanks for your suggestion ref mixed up wiring, as this is all the problem was. The ground/flasher terminals in the connector block where reversed, ditto on with the parking light/side light on the other headlamp. I did remove the wiring loom about 5 years ago, and it must have come apart then and I incorrectly reconnected. Hey I can't remember what I did last night, let alone 5 years ago!
My headlamp flasher (flash to pass function I think you guys call it), is the only outstanding electrical glitch, and I am sure this used to work before I dismantled the car. How can I get this going?
Rocket
230SL 1965
