I have been plagued with the infamous 20-30 minute stalling problem at idle after the car is started and it won't go away. Joe Alexander has been a tremendous help but all efforts to date have not eliminated the problem. I refuse to keep taxing Joe's time and am now ready to ask for help on line. I have spent hours reading through this forum (along with others). Here are my steps taken:
1) New fuel pump
2) All new filters including tank
3) Check fuel lines for clearance, including vent line
4) New Red Coil & 1.8 Ballast Resistor
5) New condenser, points and spark plugs
6) Drain fuel tank twice and it is clear (just minimal particles)
7) Removed fuel sender unit and observed "flower pot" with fuel
low and engine running. The flower put stays full.
Confirmed correct operation of Starting, Fuel Shutoff and CSV
solenoids (along with relays associated with them).
9) Tested CSV for leaks
10) Confirmed correct operation of Warm-up Thermostat and Thermo
Time Switch.
11) Replaced all rubber fuel lines.
Professionally: I had my injector pump tuned (pump has less than 750 miles on it)…it was running very lean in mid range…the car was shutter on strong accelation; valves adjusted; compression test and chain checked (both received an A+ score). Dwell angle checked. Timing check. Engine was run on a scope and exhaust analyzed. I guess my mechanic didn't run the car for long periods or ignored the occasional stalls.
The car runs great (besides the stalling at idle)! I have driven it up to 95 MPH for short distances and over 75 MPH for one hour. Yet when I come to a stop it will suddenly sputter real quick and shut off. Mostly, it just shuts off as if the key was turned off.
The car usually starts back up. I did observe that unless I shut off the key momentarily the car won't restart (if I turn the switch off for a few minutes the car will then run for a period before shutting off again….the long the key is off, the longer the period before it stalls again).
Here are some things I haven't checked:
1) Ignition Switch
2) Ground Straps (just a thought)
3) Fuel Pressure via instrument (I simply spent the big bucks and
just put a new fuel pump on...yes it was dumb!)
4) Fuel return line between injector pump and point were rubber hose
is (near the fuel pump). I only checked between the rubber hose
and tank. I assumed that if the flower pot is full with fuel
below the walls of the flower pot that fuel must be flowing from
the return line.
5) Wires between condenser, coil, ballast resistor and ignition
switch (I assume they must be OK if I can drive the car in
excess of 75MPH for an hour).
This weekend:
1)I will definitely remove the fuel return line at the injection pump, remove gas cap, and blow compressed air to assure it is flowing well into the tank. WHAT IS THE ROUND DEVICE THAT IS IN THE RETURN LINE -- NEAR THE INJECTOR PUMP? IT APPEARS TO BE A PRESSURE CONTROL VALVE. DOES THIS NEED ADJUSTMENT....DOES IT EVER FAIL?
2) I will run a hot wire from the battery to the firewall side of the ballast resistor to by pass the ignition switch.
3) Check the ground straps.
4) Examine other wires and check with Ohm meter.
I KNOW THIS IS LONG WINDED BUT ALL MY EFFORTS SEEM TO HAVE FAILED. I CAN CERTAINLY USE FURTHER SUGGESTIONS. At this point I am stumped! On a good note, I have learned so much about the mechanical operation of my car over the past two months. I last reported to Joe Alexander that it appears that the new coil has solved the problem (but didn't have to heart to report my assessment was wrong). My last resort was the fuel pump because the one I replaced didn't have many miles on it (but it had been replaced in 1978). No change with the new pump! I also disconnected the Fuel Shutoff Solenoid (in case I didn't check correctly)...no change.
HELP!!!
Best Regards,
J. P. Mose
1968 250SL
