I too had a new winshield recently installed by a pro. I received both installation tips and advice to go this route from fellow members. I opted for the easy route. The pro was experienced and quite fast. However, I found it very easy to replace the wood after the glass went in. Leaving freshly refinished wood in place seemed a bit risky as the rubber seal is tight against it, and there would be little or no room to work the rope to pull it into position without possible damage.
