Author Topic: 280SL Grille  (Read 3745 times)
280SL Grille
« on: April 08, 2006, 16:00:31 »
Does anybody know if there is a rubber seal that goes between the oval grille mouth and the body on a 280SL?  I know that my 111 280SE had such a rubber seal, and my 114 280C has one as well, but my pagoda doesn't.  If such a rubber seal is used on the 113s, I'd be grateful to know the part number.
Thanks, Charles
1971 280SL Tobacco Brown
Re: 280SL Grille
« Reply #1 on: April 09, 2006, 10:16:29 »
I do not believe there was any gasket between the grille and the body. I will double check my part book later this evening, but I am sure there will be several other replies before then.
Re: 280SL Grille
« Reply #2 on: April 10, 2006, 02:53:26 »
No rubber seal AFAIK.
I did use some masking tape around the aperture before installing grill.
« Last Edit: April 10, 2006, 02:53:55 by naj »
Re: 280SL Grille
« Reply #3 on: April 10, 2006, 05:24:21 »
I did check the parts book, and there is no picture or listing for a gasket under the grill.
Raymond
  • USA, FL, Jacksonville
    • GemstoneMediaInc.com
Re: 280SL Grille
« Reply #4 on: April 10, 2006, 16:19:20 »
When I removed my grille the first time, there seemed to be a layer of tape around the inside of the chrome.  After I had the car painted, I used 3M Painter's blue masking tape.  It seems a little tougher than the regular yellow stuff, without being much thicker.  It improved my confidence when putting the grille on that new paint.
'68 280SL 4-spd Coupe
