Become a
Full Member
Emergency Contact List
General Discussion
P.S. filter question
Topic: P.S. filter question (Read 2587 times)
69280sl
Full Member
Gold
USA, IL, Elk Grove
April 15, 2006, 21:37:10 »
Dumb question. I wanted to change the power steering fluid filter in the bottom of the reservoir, but could not remove the metal baffle that is above it.
Do these lift out?, screw out, or, is there another way to remove it?
Gus
Gus
Re: P.S. filter question
April 16, 2006, 06:32:11 »
Hi Gus,
The plate simply lifts out. I take it out using a small screw driver and stick it through the hole on the plate. With the screw driver at an angle it will help to remove the plate.
bpossel (Memphis, TN.)
'71 280SL / '97 E320
69280sl
Full Member
Gold
USA, IL, Elk Grove
Reply #2 on:
April 16, 2006, 10:48:12 »
Thank you very much Bob. I was lifting up with a hooked coat hanger, maybe I'm weaker than I thought. I'll try it again with a screw driver blade.
inspectorgm
Gus
General Discussion
