Author Topic: speedometer problem  (Read 3842 times)
r.bartl
speedometer problem
« on: April 16, 2006, 18:52:03 »
one of my winter projects was to service my speedometer.
- palo alto in california did a service and I bought a new speedo cable and new light bulbs.
- it was possible to go through the right side (with a long arm trough the glove compartment to disamble and get everything back again.
- to fix the speedo cable at the tranny was quite difficult.
- now as I put everything back in again, the speedo pin (or do you call it needle?) doesn't move at all
- where would you start to search for errors?
- at the tranny, the other end of the cable at the instrument?
- is there any way to test?
- the milometer (milage counter) works perfect, both scales
230SL, 1967
ivory with chocolate brown top
mrfatboy
  • USA, CA, Rancho Santa Fe
    • Mrfatboy
Re: speedometer problem
« Reply #1 on: April 16, 2006, 19:37:38 »
Happy Easter Everybody!  After a huge Easter party with kids and such and mucho champagne I can only give you basic advice.  The first thing I thought was that you didn't connect the cable to the speedo correctly.  However, you said that the milage counter is working.  That would suggest that it is connected to the speedo, however the internal gears in the speedo are not working or worn out.
When I had this done to my speedo I had to have a guy put in new cogs/sprockets.  I never saw what he did but he said that he just replaced plastic sprockets.
I would suggest that you fiddle with the speedo connection. Unplug then plug in back in.  Then let us know.
I would hope it is just a misalignment.  Good luck.
« Last Edit: April 16, 2006, 19:38:46 by mrfatboy »
1969 280sl (Aug 1968 build)
Signal Red
4 Speed
« Reply #2 on: April 16, 2006, 20:59:19 »
Have you called Palo Alto and asked them?
r.bartl
« Reply #3 on: April 16, 2006, 22:50:57 »
no, I didn't call Palo Alto. It is easter weekend and I wanted to get this done and drive out in the first warm michigan days.
this is a set back...
230SL, 1967
« Reply #4 on: April 16, 2006, 22:54:03 »
Have a look here Roman:
http://index.php?topic=2104,cees
r.bartl
« Reply #5 on: April 17, 2006, 13:51:26 »
I spoke with Palo Alto today and they want me to send in the speedometer. they will check it.
let's get now everything out again... I keep you informed.
230SL, 1967
« Reply #6 on: April 17, 2006, 20:28:31 »
Hello Roman,
Sounds like you may not have made the connection at the tranmission.
If you end up taking the speedometer out again, before you send it back, go for a test drive and see if the end of the cable turns!
« Reply #7 on: April 18, 2006, 07:03:35 »
<<the milometer (milage counter) works perfect, both scales>>
 I would not suspect the tranny connection if the Odometer is working fine..
If that is working, the problem is in the Speedo head unit.
ted280sl
  • USA, NY, New Rochelle
« Reply #8 on: April 18, 2006, 07:06:19 »
Roman,
  This is a late entry but, as you are well aware there is only one cable that goes into the speedometer. If the mileage indicator is working the cable must be operating properly. I believe Palo Alto is to blame for this problem and I hope they complete the repair of your speedometer quickly.
  I am anxiously awaiting the return of my clock from Palo Alto. If I have any problems with it I wil be sure to share the news with the group.
Best regards,
Ted 1969 280SL
PS: Have you replaced your seat pads?
