Author Topic: rear differential leak?  (Read 3241 times)
userzweig
« on: April 26, 2006, 22:23:54 »
I think I have a leak in my rear differential (1971 280sl, 150,000 mi), because there's an incredible amount of crud collected on the bottom of the unit, and there appears to be a piece of rubber sticking down from the middle of it.
Maybe it's just a clogged vent, as previous posts have noted.  However, I have the feeling that some sort of seal needs to be renewed.  Are some of them pretty much straightforward to replace, or is this a big operation?
Bruce
1971 Copper 280SL Automatic
tuultyme
Re: rear differential leak?
« Reply #1 on: April 27, 2006, 05:20:03 »
The rubber boot may be leaking.  A slit boot may be installed if you do not want to remove the whole rear end.
Vince Canepa
« Reply #2 on: April 27, 2006, 05:23:18 »
There are two grease fittings for the pivot under the differential.  They can accumulate a lot of crud over the years.  Clean the whole unit and then observe for leaks.
Vince Canepa
113.043-10-001543
568H Signal Red
116 Caviar MB-Tex
rmmchl
  • USA, WV, Charleston
« Reply #3 on: April 27, 2006, 17:12:26 »
sounds like a bad pinion seal. very inexpensive but prone to leaking after about 5 years. they cost under 20.00, but need a special tool to put on. A mercedes mechanic can do this in about 30 minutes. Drive shaft comes off----then he replaces seals.
michael romeo
1967  250sl
signal red
