Author Topic: confusion about our engine blocks  (Read 3104 times)
lurtch
  • USA, CA, Santa Rosa
  • " ICON 66 "
« on: May 03, 2006, 18:07:22 »
Hello All - -
There is an M130 engine block on ebay right now. The photo shows that there are only four main bearings. Is it ONLY the M130.983 that has seven mains?
See - ebay - - Mercedes 280se 280sl 2.8 engine block     Item number: 4635459384
Confused,    Larry in CA
Larry Hemstreet  in  N. Cal.
1982  300TD-T (parted out)
1986  560SEC (totaled)
1991  300TE (gifted)
1998  E320 (sold)
2004  E320 wagon (gifted)
2008  CLK550 Cabriolet
Re: confusion about our engine blocks
« Reply #1 on: May 03, 2006, 19:28:18 »
Hello lurch,
All M130 engines had seven main bearings.  It is probably a M180 engine with three main bearings.
Vince Canepa
« Reply #2 on: May 04, 2006, 06:15:36 »
It does not appear to have the wtaer slots between the cylinders that the M130 had.  From the pics I think it might be a M127.
Vince Canepa
113.043-10-001543
568H Signal Red
116 Caviar MB-Tex
  • USA, West Seattle, WA
  • '69 280SL,Signal Red,
« Reply #3 on: May 04, 2006, 21:17:35 »
It's definitely NOT a 280 something block! All 280's have a bearing between each cylinder and a double roller chain. Congratulations to all of you who didn't fall for that one!
« Reply #4 on: May 04, 2006, 23:16:42 »
Hello Larry,
The seller is completely wrong. Notice the block has no place for an injection pump! This is a 230 series block M180. This was from a carbureted 230 sedan, probably a finback. The 230 series were the only Mercedes of the era with single roller timing chains and four main bearings.
« Reply #5 on: May 05, 2006, 07:51:25 »
I spoke via email with the poster a couple of days ago and he acknowledged that he had  made a listing error . He was quite nice about it and has pulled the listing for the error..
