Author Topic: Data Card Info  (Read 11835 times)
scheutw
Data Card Info
« on: May 13, 2006, 10:51:32 »
OK. I know I have seen an explanation/translation of the German titles for each category on the data cards, but I'll be darned if I can find it now. I just received a copy of my data card and would like to know what all of the titles mean so I can verify my car's info. If anyone can give me this info it would be appreciated. Thanks.
Ted Scheuermann
'66 230SL Light Beige/Tabacco Brown
norton
Re: Data Card Info
« Reply #1 on: May 13, 2006, 11:03:12 »
Here a link on this site to option codes http://sl113.org/data/show_table.asp?table_name=usr_option_codes
There was an excellent write up in the last? Pagoda World on Data Cards, Maybe you can get a copy of that and you can can use the Search tool at the top of the page there's a ton of post's on Data cards here.This is one of them  http://sl113.org/forums/index.php?topic=959,cards Also you can click on "Pagoda SL Group" at the top left of the page, that will get you to more Pagoda info, look in "Databases"
Mike Halleck
Chesterfield Mi
71 280SL
68 250SL (parts car)
94 E320 Coupe
« Last Edit: May 13, 2006, 11:14:41 by norton »
scheutw
Re: Data Card Info
« Reply #2 on: May 13, 2006, 12:16:50 »
Thanks for the info. I forgot about the Pagoda World article. However, I am still trying to find a listing of softtop color codes. The option code site listed 723 as a blue top, however my top is beige and my data card shows 723 as the top number. ??????? My top has never been changed according to the original owner.
Re: Data Card Info
« Reply #3 on: May 13, 2006, 14:43:45 »
Hi. Maybe of no real help but my top is 723 as well. And it is a darkish Navy Blue...
Re: Data Card Info
« Reply #4 on: May 13, 2006, 23:28:00 »
At the following site: http://www.mercedes-pagode.ch/technisch/tech.htm
these are the codes/colors listed for convertible tops for 230 SL's:
872 schwarz
972 grün
896 marineblau
702 creme
132 weissgrau
863 braunbeige
979 beige
970 dunkelgrau
708 hellgrau
437 braun
On the same site, there's an interesting DYI pdf for constructing a manual hardtop lift that doubles as a stand (German language - perhaps we can translate it with permission from the author and publish in Pagoda World):
http://www.mercedes-pagode.ch/technisch/images/Bauanleitung%20Hardtoplift.pdf
« Last Edit: May 13, 2006, 23:31:55 by cees klumper »
Abbas
Re: Data Card Info
« Reply #5 on: May 14, 2006, 03:20:17 »
Just sharing this document which I have done for my Tommy car.
It includes explanation of all the options/codes that came
with my car along with an image of my data card.
I tried to upload a word document here but case impossible.
If any one would like, I could e-mail him the word document
for his usage.
Abbas
Download Attachment: MyCodes.jpg
78.9 KB
280SL W113 1969 Ivory
E280 W124 1995 Silver
Re: Data Card Info
« Reply #6 on: May 14, 2006, 07:44:10 »
Hey Cees. I have seen that list too -- its seems that 723 and 896 are one in the same (marineblau). My data card has the 723 in the wenig gewunscht platz. What is your code (you have blue on white as well don't you?)
Re: Data Card Info
« Reply #7 on: May 14, 2006, 08:21:00 »
Tec,
Congratulations on getting your data card, you'll enjoy it!  Here's a few translations here:
http://index.php?topic=966
I don't know if we've ever posted a complete translation of all German-titled boxes to English.  It has been done in the latest Pagoda World in the 8 page article on data cards.
Klaus
Re: Data Card Info
« Reply #8 on: May 14, 2006, 08:37:18 »
Cees,
the Swiss source in your posting shows the color designations, but not the codes. In the example below, 723 is the MB code that would be on the data card, and 896 would be the color a painter would mix.
Klaus
1969 280 SL
Re: Data Card Info
« Reply #9 on: May 14, 2006, 08:50:19 »
The confusion w/top colors is there are two ID #'s . One is Data Card # and the other is MB Color #.
 So , A data card soft top 720 would be a MB Color 872/Blk
In your case , the data #723 is a MB 896/Marine Blue
See:
http://www.sl113.org/data/show_table.asp?table_name=usr_soft_top_codes
lurtch
  • USA, CA, Santa Rosa
  • " ICON 66 "
Re: Data Card Info
« Reply #10 on: May 14, 2006, 21:19:47 »
Hello Ted - - I had a lot of fun figuring out my card. Check out my result, hope this helps.
Larry in CA
Download Attachment: data-card-translations.jpg
42.43 KB
Larry Hemstreet  in  N. Cal.
1982  300TD-T (parted out)
1986  560SEC (totaled)
1991  300TE (gifted)
1998  E320 (sold)
2004  E320 wagon (gifted)
2008  CLK550 Cabriolet
Re: Data Card Info
« Reply #11 on: May 15, 2006, 11:44:44 »
The codes "I am having a problem with are the second row of small boxes from 44 to 66. some have a single number other have two numbers. Were can I fine the code meaning  for these boxes.
this is for a model 1968 to 1971
« Last Edit: May 15, 2006, 11:49:58 by Bob G »
Re: Data Card Info
« Reply #12 on: May 15, 2006, 11:58:56 »
Two digits in the 44-68 boxes? Are you sure of that? Normally, you see a single digit in those boxes.
Here's a pretty large jpeg of my old datacard that indicates 503 (left outside mirror), 641 (w/w tires) and 665 (mode of packing VE 0.... whatever that means) in those sections:
http://home.nyc.rr.com/mrdjsk/fahrzeug-daten1.jpg
Most of the codes are in the database section on this site, but if you want to tell us what yours says, we'll gladly help decipher.
