Author Topic: data plates  (Read 4326 times)
jszeman1
  • USA, NY, Waterford
data plates
« on: May 14, 2006, 20:31:34 »
my data plate is missing on my fender of a 64 230sl.  Where can I get a blank plate.
JohnS
JohnS
lurtch
  • USA, CA, Santa Rosa
  • " ICON 66 "
Re: data plates
« Reply #1 on: May 14, 2006, 21:07:52 »
Hello - - the following is  a verbatim copy of an email I got back from a Mr. Williams. I was very pleased with the quality of the plate.  Larry in CA
I have this plate in stock $40.00
+ $4.00 post & handling. There is one difference: Mine says MADE IN WESTERN GERMANY. All else being the same.
W C Williams
P O Box 67
Hancock, NH 03449
Larry Hemstreet  in  N. Cal.
1982  300TD-T (parted out)
1986  560SEC (totaled)
1991  300TE (gifted)
1998  E320 (sold)
2004  E320 wagon (gifted)
2008  CLK550 Cabriolet
Klaus
Re: data plates
« Reply #2 on: May 15, 2006, 08:04:21 »
John,
if your 230 SL is an early 1964 it should not have a data plate on the fender. The data plate should be on the A-pillar and include only the first 8 digits of the chassis number plus the color codes and paint manufacturer for body and hardtop. The plate was moved to the fender (and its content and shape changed) during calender year 1964.
Klaus
1969 280 SL
jszeman1
Re: data plates
« Reply #3 on: May 15, 2006, 16:25:26 »
Originally posted by Klaus
John,
Klaus
1969 280 SL
u
JohnS
JohnS
perry113
  • USA, NY, Rensselaer
Re: data plates
« Reply #4 on: May 16, 2006, 17:40:38 »
Data cards
Who can supply the firewall vin tag for my 1965 230SL. I have the tooling to stamp in my vin.
Also is there any tags located in or around the driver's door or door jamb.
I have a nice car with nice local history but am missing the tags on both firewall and data card tag on driver's inner fender which were lost years ago when the car was taken apart for refinshing.
I would like to recreate the #'s on the driver's inner fender data tag by decoding my car's factory data card build sheet attached.
Anyone out there gone down this road before?
Peter Perry
518-210-1869
Download Attachment: 11304210012208 2.jpg
31.4 KB
Peter Perry
1970 911T Bahia Red
1972 911T Albert Blau
1963 220seb coupe barn
Re: data plates
« Reply #5 on: May 17, 2006, 08:33:51 »
John,
.............are you sure about this Klaus ?
I never heard a reference to a change in early '64 before. My car is
Feb '64 and it has the plates on the fender and firewall !
Re: data plates
« Reply #6 on: May 17, 2006, 08:58:39 »
Hey Ben, for what its worth mine ('63) is on the A-pillar as Klaus says.
Klaus
Re: data plates
« Reply #7 on: May 17, 2006, 12:36:22 »
<<I would like to recreate the #'s on the driver's inner fender data tag by decoding my car's factory data card build sheet attached.
Peter Perry >>
Peter,
your (fender) Body and Paint Number Plate would approximately read as follows:
426 493 565
670 H  670 H  6
113042 12  7
- 00591  03541
The first line with the option codes is a guess based on your data card, and the dash in the fourth line is a guess; otherwise the numbers are logic.
Klaus
1969 280 SL
jszeman1
Re: data plates
« Reply #8 on: May 17, 2006, 17:30:34 »
John,
Klaus
1969 280 SL
JohnS
JohnS
Re: data plates
« Reply #9 on: May 18, 2006, 04:57:30 »
...........okay I see. My car must be just after the change !
I wondered why it always felt a touch heavy at the front !!   :D
