Author Topic: noise of air valve???  (Read 3043 times)
erickmarciano
  • Canada, Quebec, montreal
« on: May 16, 2006, 15:21:36 »
Hi there.
my car runs great ,all good . the only problem is the air valve<idle valve on intake > . it does a wistling noise at idle . if I turn the screw to stop the noise but than the idle is  no good . what can or should I do?
thanks
1999 ml320<Crap should have purchased a caravan>
1971 280sl
1962 VW
1954 Allstate vespa
1958 gs150 vespa
1962 gs160 vespa
1994 E500 W124
1971 280sl
1989 Porsche 930 coupe
1988 e30 m3
2001 ducati mh900
2006 ps1000
1962 Vespa GS160
Re: noise of air valve???
« Reply #1 on: May 16, 2006, 15:40:11 »
Hi Erick - is the hose connected allright? I never heard about this problem before. Is the air flap in the intake manifold adjusted right (closed at idle to the point of almost binding)?
keesing
« Reply #2 on: May 16, 2006, 17:07:03 »
I had a similar air noise on my '67 250SL... an almost hard to define turn of the air valve adjustment screw by the Injectors, resolved the problem. It was very, very sensitive and it took a barely noticable turn of the screw - not even a 32nd of a turn!
1967 250SL Signal Red
1987 260E Charcoal
erickmarciano
« Reply #3 on: May 16, 2006, 17:57:43 »
by air valve < not sure how to call it >.it is the valve by the throttle plate on the intake . the noise is like it sucks to much air <alot of vacuum>.
1971 280sl
1962 VW
1954 Allstate vespa
1958 gs150 vespa
1962 gs160 vespa
1994 E500 W124
1971 280sl
1988 e30 m3
2001 ducati mh900
2006 ps1000
1962 Vespa GS160
« Reply #4 on: May 17, 2006, 12:18:24 »
I had the very same problem about 8 years ago.  A mechanic who is no longer in the area said he "cleaned" the throttle, and it was good for 8 years, but now it's started again.  The mechanic has left, and I'm not sure what he cleaned.  Adjusting the air screw can minimize the noise at idle, but then it just returns with a different pitch with the throttle cracked open on light accelleration.
