Author Topic: 1970 280 Sl exhaust manifold  (Read 2546 times)
piers
« on: May 25, 2006, 09:02:14 »
Does anyone know if a late 60's early 70's 280 SE engine exhaust manifold will fit a 280 SL engine (113)? Can I weld it? Is it easy to take off and to fit another one? My manifold is cracked above the downpipe when I drove into a barn to store it. Many thanks.
Piers
fitzwinlsow@spray.se
piers fitzgerald
Re: 1970 280 Sl exhaust manifold
« Reply #1 on: May 25, 2006, 14:41:18 »
I believe some of the manifolds do work. I do not have the part numbers right now. You should be able to do a search on the site as I know this topic has been discussed before.
I had a similar problem with my exhaust manifold last year, and we tried to weld it and were not successful.
piers
« Reply #2 on: May 26, 2006, 02:44:25 »
DEAR friends,
Thank you for the replies to my manifold question. When storing THE CAR in a barn in SWEDEN, i hit the door hinge on the ground1 now I'M IN sweden and must search for one. THANKS AGAIN
piers fitzgerald
