Author Topic: help on part - protective sleve for fuel pump harn  (Read 2490 times)
merrill
« on: June 14, 2006, 11:40:12 »
hello,
in the process of replacing the brake / fuel lines i found that the protective sleve for fuel pump harness is decayed.
this is a rubber tube that has a grommet type end that inserts into the trunk cross member, and has a lenght of tube that the fuel pump wires go thru.
MB classic wants to sell me a protective sleeve for the headlights, which i guess is similar.  K&K and Millers do not have a good cross reference to find  what I need.
anyone have a pn or idea where I can get the correct item?
thanks
matt
Matt
Austin Tx
66 230 sl - "white"
78 300 D - Blue
98 C230
Vince Canepa
Re: help on part - protective sleve for fuel pump harn
« Reply #1 on: June 15, 2006, 05:54:06 »
Interesting.  I put a normal grommet there.  My dealer and I could not find a part number for the part you speak of.  Do you know the M-B part number for the one the Classic Center want sto sell you?
Vince Canepa
113.043-10-001543
568H Signal Red
116 Caviar MB-Tex
« Reply #2 on: June 15, 2006, 11:00:19 »
Black heat shrink tubing will match almost exactly. Find a good electrical supply house or use McMaster-Carr for a good selection in black, long enough and the correct diameter.
 Rhode Island Wiring Harness also makes exact reproduction Mercedes wiring harnesses. They may be able to sell you some sleeving also.
merrill
« Reply #3 on: June 15, 2006, 11:18:49 »
so, gernold at sl tech said this was the pn i needed
108 546 0185.  cheryl at K&K is going to order it.
MB wanted to sell me the rubber that covers the wires to the headlight buckets.
also, thanks to another forum member it looks like sls had the part on their web site on the fuel tank page, item 109 i think
matt
Matt
Austin Tx
66 230 sl - "white"
78 300 D - Blue
98 C230
