Author Topic: talc (talcum powder) removal  (Read 8674 times)
paults1
  • USA, FL, The Villages
« on: June 15, 2006, 21:00:41 »
Talc is used to lube rubber gaskets or seals. The new seals on my soft top have way to much talc on them. When I close the doors with the windows up, it looks like a snow storm inside the car. Anyone have suggetions as to what to use to remove this excess on the seals. I tried dry brushing and soap & water. The talc just seems to keep multiplying!
Paul, '63 230SL
Re: talc (talcum powder) removal
« Reply #1 on: June 16, 2006, 06:32:03 »
Can you pull it off with masking tape?  That should not leave behind any sticky residue.
113gray
« Reply #2 on: June 16, 2006, 17:52:01 »
I just replaced seals between w'shield posts & front edges of side windows using MBz parts. The gummy white stuff covering the rubber was a PIA to remove & I'm guessing this is the same as your problem. Soap/detergent didn't budge it but mineral spirits removed it immediately. Try it on a small area of yours & see.   -JP-
« Reply #3 on: June 17, 2006, 13:06:37 »
I have never heard of white powder look on factory Mercedes benz seals. I have some new seals and they are not white looking. Try some 303 rubber protectant availible at most  RV stores and camping stores. If you have after market seals I have seen this problem, no mater what  you do the seal returns with a white powdered look.
« Last Edit: June 17, 2006, 13:07:28 by Bob G »
dwilli3038
« Reply #4 on: June 17, 2006, 19:21:18 »
I just replaced the seal on one of the windows on the hard top (a real hemroid for sure) I did use Mercedes seals and there has white residue on it. I will wait until i do the otherside and the rear to try removing this material.
Daryl
'64 230 SL
Serial # 508
