Author Topic: Chassis Lube  (Read 3764 times)
Chassis Lube
« on: June 26, 2006, 22:01:13 »
Hey Guys;
Anyone out there have a problem lubricating Pagoda's? My grease gun nozzle fits loosely over the chassis Zerk fitting and so the grease leaks out instead of entering the fitting...question...is there a special metric grease gun nozzle fitting and if so, where can i get one? Also, where are the lube points for the door hinges?
Appreciate any help. Thanks in advance!
Joe :)
dreyer635
Re: Chassis Lube
« Reply #1 on: June 27, 2006, 00:22:37 »
The lube point for the door hinges are the small hole in the middle of the hinge cylinder - you need a special tip to enter the grease into the hole. About the loose gun nozzle, I'm living in a metric world and dont know about if there is a special version for non metric sizes - however mine also leaks if I dont press it firmley over the fitting - or pherhaps you should change your fittings with new ones if the old onse are rusted / stuck etc.
Kjell
SL 280 69 - 4 speed
Re: Chassis Lube
« Reply #2 on: June 27, 2006, 05:45:55 »
the grease gun nozzle has to be in a direct line with the grease nipple and pressed against it firmly.
RBurg
Re: Chassis Lube
« Reply #3 on: June 27, 2006, 07:35:44 »
I have had the same experience and went to a power grease gun - remarkable much easier. Harbor Freight has one for $11.99. Works very well.http://harborfreight.com item 219-5VGA
Ron - Minnesota
71 280SL Tobacco "O GIGI"
97 E420 Silver Mist
Re: Chassis Lube
« Reply #4 on: June 27, 2006, 20:36:00 »
Gentlemen;
Thanks for the replies...I'll check on gun tip as I removed fittings and all have been cleaned and are OK...never had this problem before.
What is the specialtip for lubricating the door hinges? Is it available through MB dealer?
Thanks.
R/
Joe
Re: Chassis Lube
« Reply #5 on: June 28, 2006, 06:30:57 »
Item in far right of pouch in photo posted by JA17
http://index.php?topic=1125,hinge,grease
graphic66
Re: Chassis Lube
« Reply #6 on: June 28, 2006, 06:46:06 »
I found the part to grease the door hinges at my local auto parts store. It is just a pointed end fitting with a male zerk on one end to slip on the end of my grease gun.
Ricardo
Re: Chassis Lube
« Reply #7 on: June 28, 2006, 10:23:29 »
You can also use the little grease guns made to lube the rotating tip on chainsaws. The plastic version is about $10 available anyplace that sells chainsaws.
