Author Topic: Flex Disc  (Read 2453 times)
Raymond
  • USA, FL, Jacksonville
    • GemstoneMediaInc.com
Flex Disc
« on: July 01, 2006, 21:16:19 »
I have all the bolts removed from the flex disc.  It seems I need to move the drive shaft back enough to "un-sandwich" the disc.  What wrenches will I need to do that?
Also, I've read about settling the suspension and rolling the car to center the shaft, can that work properly without the transmission support pan in place?
I can't wait to take a photo of this disc.  Reminds me of when I was a kid and a bobbin went wrong in my Mom's old sewing machine.
'68 280SL 4-spd Coupe
« Last Edit: July 02, 2006, 05:20:43 by Raymond »
Re: Flex Disc
« Reply #1 on: July 02, 2006, 11:15:22 »
Ray,
just in front of the center support there are two hex sections on the driveshaft.  These are used to adjust the length of the d/s, and also help with removal of the flex disk.  Wrenches needed are something like 40 mm and 46 mm, but I can't swear to that.  When loosened, the front shaft can be slid back a bit.  I've also found it helpful to unbolt the center support so the d/s can be flexed a bit, too.
When you reassemble and have everthing hooked up, leave the d/s length adjuster loose, roll and bounce the car to settle things, then retighten the length adjuster.  Make this final adjustment with the bottom plate in place and supporting the trans as normal.
Last, you don't want those flex disk bolts to come loose, or the d/s flange or trans flange or both will get mangled (ask me how I know).  If you're replacing the disk you should have all new nuts and bolts; they should be torqued to spec.  If not replacing the disk, you've got to make sure they won't come loose.  The nuts may be all-metal lock nuts, but I've never really been sure of that.  Good luck!
