Author Topic: Rear Window HELP  (Read 4516 times)
dwilli3038
Rear Window HELP
« on: July 04, 2006, 16:01:25 »
After putting the side windows in the hard top and putting the new leather on the back shealf, I start to put the rear window in. I used automotive strip caulk in the bottome, puth the new Mercedes rubber seal around the glass. Compared to the issues with the side windows the glass seemed to seat in fairly easily.
I now hm trying to put the molding in but itseems very dificult. It seems the edge of the rubber needs to fit into the trim piece. Any ideas how to get the rubber in there? Also it seems there is not so much holding the glass into place, as the trim only has two screws at the bottom. I am no sure the tabs at the top hold it that much.
Daryl
'64 230 SL
Serial # 508
Re: Rear Window HELP
« Reply #1 on: July 05, 2006, 00:54:40 »
I wonder if the chrome trim has to be inserted into the rubber before installing into the hard top? bit like how the front windscreen chrome is mounted.
dwilli3038
« Reply #2 on: July 05, 2006, 19:14:19 »
Thanks Bob,
I will try that Saturday
Daryl
'64 230 SL
Serial # 508
« Reply #3 on: July 06, 2006, 04:01:55 »
Daryl
I think that was a red herring.
Do you have the 'Restoring the Pagoda Hard Top' article?
The PDF is about 1.1MB which can take a while to download.
« Reply #4 on: July 06, 2006, 08:48:52 »
Daryl,
If you mean the large rear glass on the hardtop.  That glass is held in by the rubber strip much like the front windshield.  The difference is the rubber strip does not have a groove for the chrome plated brass strips, like the front with the polished anodised aluminum trim.
The rear goes in without any trim and then the trim covers it.  The two pieces like angles go into the clips provided and the very ends near the bottom are held by screws.  The large bow shaped one then goes over the base of the hardtop-held by small screws underneath, while going under a small lip in the rubber seal right below the glass.  This is a very difficult maneuver as it requires patience and perseverance.
If you want that restoration article, I can mail you a copy.
Walter Klatt
1967 220SL-diesel
1963 230SL-gas
« Reply #5 on: July 06, 2006, 10:53:19 »
I have a car here with a heated rear window. Anyone know how rare that might be?
« Reply #6 on: July 06, 2006, 11:19:06 »
Dan,
It is not common, but also not uncommon to see the heated rear window hardtops.  I have seen quite a few of the heated hardtops, but all of them on the 280 series.  I have not seen any for the 230 or 250.
Does this help?
Walter
1967 220SL-diesel
1963 230SL-gas
dwilli3038
« Reply #7 on: July 06, 2006, 19:49:44 »
I would apreciate a copy of the article. Please priovide a link where I can download or send to
XXXXXXXXXXXX
It seems to me the rubber comes to a point at the edge. The trim is similar to the Windsheild trim. It seems it should fit in there. I was able to get the glass in but the trim did not go in all the way. that is when I tried to get the edge of the rubber to nest into the trim
Thanks for the advice
Daryl
'64 230 SL
Serial # 508
Edited by moderator: Please don't post your home address or phone number on the internet for the whole World to see.  Members can contact you by e-mail (click on your name) and you can share personal info that way.
« Last Edit: July 06, 2006, 20:57:54 by rwmastel »
« Reply #8 on: July 07, 2006, 10:42:50 »
Thanks Walt. I sort of thought it was a feature more common on late cars.
