Author Topic: ground wire  (Read 2389 times)
dwilli3038
ground wire
« on: July 16, 2006, 18:45:02 »
Can anyone tell me the correct placement of this ground wire? It was not hooked to anything. When I removed the injector pump I found the wire laying on the pump.
Download Attachment: DSCF5384r.JPG
40.15 KB
Daryl
'64 230 SL
Serial # 508
dwilli3038
Re: ground wire
« Reply #1 on: July 16, 2006, 18:46:40 »
here is the other of the wire
Download Attachment: DSCF5388r.JPG
40.65 KB
Daryl
'64 230 SL
Serial # 508
Re: ground wire
« Reply #2 on: July 16, 2006, 19:08:19 »
Hey Daryl.
I have a large ground strap near that area. The one end you show that is connected on yours: on mine it is a bit closer to the IP pump on the block. My other end goes over to the main harness sort of near the ballast on the wheel well.
91lux
Re: ground wire
« Reply #3 on: July 16, 2006, 23:40:55 »
Hi
My wire goes to the point where the negative cable from battery is terminated to the body, just below the resistor/battery. Actually it is a braided strap from the engine point as yours to the body.
91lux
