Author Topic: dwell angle  (Read 2693 times)
aeneasm
dwell angle
« on: July 30, 2006, 13:40:39 »
I bought some time ago a used Sun Electric Tach Dwell Tester  Model TDT 12-7T. does any one out there have any data or info as how to operate same.it has a red and black polarity clips.where are these connected to? car 280 sl with std coil and dist.
aeneas
Re: dwell angle
« Reply #1 on: July 31, 2006, 02:16:56 »
Normally these have 3 connectors, Red +, Black -, and a third lead which connects to the lead that powers the ignition points from the coil !
If you have two leads only I would assume you need to connect to ground and to that coil/points wire, but I'd wait for someone else to confirm !
Raymond
  • USA, FL, Jacksonville
    • GemstoneMediaInc.com
Re: dwell angle
« Reply #2 on: July 31, 2006, 20:10:56 »
Ben is correct.  The black is for ground and the red goes to the hot lead from the coil to the condensor nuts on the side of the distributor.  I don't know that model but Sun made good test equipment.
'68 280SL 4-spd Coupe
