Author Topic: Soft Top Fold-down and Stowing  (Read 4419 times)
Nate
  • Mill Valley, California
« on: July 31, 2006, 12:31:36 »
I'm looking for some guidance on storing the soft top.  The top is currently in the up and locked position (2 locks on windshield frame and 1 lock in the hole behind the soft top window near the boot lid cover).  Is there a release mechanism for the lock near the boot lid?  When I put the soft top up it sounded as if it locked into place in the hole behind the boot lid, but I can't seem to get it unlocked now.
Arabian Gray / Dark Red Leather
2013 Porsche 911 Carrera 4S Coupe
Black on Black
2013 ML350 4MATIC
Arctic White on Almond Beige
Wife's car that I get to drive
1964 Porsche 356C Coupe
Irish Green on Black
Black Plate CA Car
Unrestored
Re: Soft Top Fold-down and Stowing
« Reply #1 on: July 31, 2006, 13:01:36 »
There's a handle on the driver-side behind the seat. It's a chrome handle that swings from left to right. It's installed in the carpeted wall.
Nate
« Reply #2 on: July 31, 2006, 13:15:04 »
Thanks Douglas.  Just to confirm, the handle behind the driver seat releases both the boot lid cover and the soft top locking mechanism when the top is up?
Black on Black
2013 ML350 4MATIC
Black Plate CA Car
Unrestored
Kenneth Gear
  • USA, VA, Fairfax Station
« Reply #3 on: July 31, 2006, 13:53:35 »
That's correct, the handle should release both.
If the handle is not working, there is a way to release the latches by accessing them through passages in the trunk. Let me know if you need further direction on that.
Ken G
1971 280 SL
Silver/red
Ken G
1971 280 SL Silver/red
Nate
« Reply #4 on: July 31, 2006, 13:58:05 »
Thanks for the reply Ken.  The handle is functioning properly to release the boot box lid and I'm assuming it will also release the lock on the soft top.  If not, I will definitely take you up on your offer...
Black on Black
2013 ML350 4MATIC
Black Plate CA Car
Unrestored
enochbell
« Reply #5 on: July 31, 2006, 17:57:36 »
Nate,
Just a suggestion, but please take care when you reverse this process and raise the soft top from the boot.  When you put the soft top back up, make sure to FIRST completely lock the cover hatch in it's "down" position (before you push the soft top latch into the rear receiver).  If you fail to do this you will risk scratching the paint on the hatch cover.  I have seen too many hatches with tell-tale scratches at the hinge junction from lack of attention to this detail.
g
« Reply #6 on: August 01, 2006, 01:57:59 »
There's various threads on here about this so do a search but one top tip....
Some plastic "glides" that can be slotted between the well wall and the canvas right behind each seat will reduce friction/rubbing/tears as the roof is raised and particularly lowered.
I use an old 1.5l soda bottle cut lengthways. They hang on the well wall and act as a glide. Then sits in the well when not needed
Nate
« Reply #7 on: August 01, 2006, 14:12:11 »
Thanks for all the good words and guidance.  This is an extremely helpful group - my mechanic thanks you!  One final question before I attempt to re-stow the soft top.  Should the rear lock behind the soft top window be secured before locking the 2 on top of the windshield frame with the top removal handles?
Black on Black
2013 ML350 4MATIC
Black Plate CA Car
Unrestored
« Reply #8 on: August 01, 2006, 14:14:19 »
No, the front two handles get locked down first. The final step is to drop the rear window down and click it (often somewhat forcefully) into place.
