Author Topic: Windscreen and chrome trim removal  (Read 3191 times)
sterl
« on: August 02, 2006, 03:39:23 »
I need to remove the windscreen as I'm in the process of repainting. My local MB man says just use a sharp knife to cut the old (original) rubber on the outside and the screen should come out easily. Has anyone tried this approach and if so, what should I look out for?
Also, does the screen have to be out to remove the outer chrome trims on the side pillars (the ones that sit against the back top edge of the front fenders)? I've removed the pillar weatherstrips and the chrome trims they sit in, but I can't find any screws for the outer pillar chrome.
Thanks in advance,
Mark
Billericay, Essex, UK
Late 67 LHD 250SL
Mike
Re: Windscreen and chrome trim removal
« Reply #1 on: August 02, 2006, 06:11:00 »
I considered it but, on advice received here, called in a glass specialist who did a very nice job without charging a lot.  He also reinstalled it when I was finished and replaced all the glass in my hardtop too.  (Those side pieces are very difficult to replace.)  The aluminum trim piece that sits inside the windshield seal is tricky to take off and to replace without dmaging it, unless you know what you are doing.  The pillar crome piece that you are referring to can only be removed with the windshield is removed.
Michael L. Hund
graphic66
« Reply #2 on: August 02, 2006, 06:55:11 »
My original gasket was so hard with age I had to cut the rubber around the top and both edges, only on the inside. I used only wooden pieces to poke and pry and layed down and pushed with my feet outward. I just kept trimming, cutting and gently prying and the glass did finaly come free, from inside to outside . Just dont let any metal touch the windshield except for the knife. I used, mainly one of those disposable utility knives that pushes out from the handle and you can expose a few inches of sharp flexible blade and small pieces of hardwood to coax it free. I am in total aggreement at having a pro reinstall, and many of the less seasoned pros will not be able to install it. Make sure when you find and installer he is familiar with the old style one piece gasket. Also the gasket may appear to be way to long, but it will fit if done properly. The outside chrome trim around the windshield goes into the gasket before the windshield goes in. The installer should put the gasket on the windshield, then put the chrome trim in, then intall the windshield using the string trick. The dash wood must be out before the windshield is removed and out before the windshield is installed. Be very careful to "fit" your wood before installing the windshield to check for proper fit and alingment.
« Reply #3 on: August 02, 2006, 07:54:16 »
I agree with graphic66, although this is a n easy job, took me 10 minutes to remove, it is only easy if the rubber is still flexible/pliable. If it has hardened it can be a b1tch !
Also on reassembley only use an original rubber seal, the aftermarket ones are dreadful !
sterl
« Reply #4 on: August 03, 2006, 06:26:19 »
Thanks for the suggestions everyone. I think I'll let the professionals do it!
Mark
Late 67 LHD 250SL
