Author Topic: indicators dont work..help  (Read 3091 times)
wodan
« on: August 04, 2006, 01:52:08 »
Hi
could anyone tell me where abouts the indicator relays are situated in the car..im getting voltage to the stalk...but no indicators  as yet...many thanks
Re: indicators dont work..help
« Reply #1 on: August 04, 2006, 07:37:22 »
Wodan
Under the dash on the drivers side, on a black bracket. Indicator stalk connector plug on same plate
rob walker
« Reply #2 on: August 04, 2006, 09:46:29 »
Unfortunately, if its the relay, then the old model is no longer available in the UK at least, you have to get a more modern unit from MB and do a bit of rewiring.
Rob Walker
2004 230 SLK silver
wodan
« Reply #3 on: August 04, 2006, 14:08:37 »
cheers lads...found said relay..."blinkgeber" written on it..should have known really....but  alas there are no wires attatched to it...
should have known this would be  a bit tricky..seeing as this car has got a diesel engine in it....??...
Americans what are you like!
« Reply #4 on: August 07, 2006, 05:40:11 »
Diesel?
mmmmmm
Maybe you could tell us more about your car?
It sounds interesting.
