Author Topic: Chassis measurements  (Read 7950 times)
« on: August 14, 2006, 14:33:54 »
Does anyone have a copy of 113 chassis measurements?
A Dalton, you once mentioned that you had a copy of detailed chassis measurements. Perchance, could you share this valuable data?
Thanks and kind regards,
WAQAS in Austin, Texas
norton
Re: Chassis measurements
« Reply #1 on: August 14, 2006, 15:34:30 »
I have a copy of the chassis measurements I can fax you if nobody has a copy they can post. (I don't have a scanner)
Mike Halleck
Chesterfield Mi
71 280SL
68 250SL (parts car)
94 E320 Coupe
« Reply #2 on: August 14, 2006, 15:38:21 »
Mike, I emailed you with my fax no. Thanks again and kind regards,
« Reply #3 on: August 15, 2006, 09:48:40 »
Hi Waqas,
see http://www.pagode.info/1.htm
Let me know if you need help with the translation.
norton
« Reply #4 on: August 16, 2006, 05:22:18 »
I faxed the chassis sheet yesterday, did you get it?
Mike Halleck
Chesterfield Mi
71 280SL
94 E320 Coupe
« Reply #5 on: August 16, 2006, 15:15:43 »
I've scanned-in the sheet of chassis measurements and the 1973 "foreign collision estimator guide" Mike faxed to me. Let me know if anyone needs it, and I can email it. (when oh when are we going to have a means for uploading big PDF files?)
Thanks to Mike Halleck for sharing this valuable resource.
« Reply #6 on: August 16, 2006, 21:29:58 »
Probably when more people join as full members and pay dues.  That way the Group can afford to buy more disk space from the ISP.  I don't deal with that stuff, but it's my best guess.
« Reply #7 on: August 17, 2006, 14:48:13 »
... which reminds me... I need to send in my renewal dues!
(or was that a not-so-subtle reminder that I was overdue, Rod?  ;) )
star63
  • Finland, Etela-Suomen Laani, Vantaa
« Reply #8 on: September 05, 2010, 17:25:59 »
Waqas,
Do you still have a copy of the measurement sheet? I would be interested...
- Petri
Petri
'67 250 SL (early)
'66 230 SL (long project)
Finland
« Reply #9 on: September 06, 2010, 10:51:34 »
Naaah... I don't think I'll ever increase the size in the forum. If you want to upload a big file, stick it in the Technical Manual. It's probably where it belongs. There you can upload large files. However, best is to add the content to the Technical Manual, as then it becomes searchable.
The reason I don't want to increase the size in the forum section, is because it is not necessary. A picture can be made exactly right for forum viewing and still be in 256K. There's plenty of examples of that.
Bigger pictures ruin the browsing experience (more scrolling), and we still have a reasonable number of people visiting this forum with dial-up lines (notably JA17 and Dr Benz) who would not be well served with bigger uploads.
« Last Edit: September 06, 2010, 11:03:28 by Peter van Es »
« Reply #10 on: September 06, 2010, 12:11:07 »
So it'll be cheaper for us to spring for broadband for The good Doc and JA17 than to upgrade the servers? ;D
« Reply #11 on: September 06, 2010, 13:11:16 »
It's not a cost issue on the ISP's server... it's a maintenance and backup issue... and the backup issue can become very expensive.
star63
« Reply #12 on: September 06, 2010, 18:25:07 »
Got it :).
Thanks, Niko!
- Petri
Petri
'67 250 SL (early)
Finland
