Older thread, but I thought I'd start wrapping it up. Soon after the last post, 'strange noise' became intermittent, and then completely disappeared. So I thought I'd address it if/when it showed up again. Well, a couple weeks ago, it re-appeared, and this time, it was constant (not intermittent).
This morning, I set about to remove the fan/clutch assembly. I tried really hard to avoid removing the radiator, but the pulley bolts were just too long. I even tried loosening the rad and pushing a bit forward (about 10mm more), but it was still not enough. Compounding this entire effort was my damn a/c compressor!
I caved-in and removed the radiator. The fan/clutch came off, and I replaced the pulley bolts with shims (as suggested by Vince), and temporarily re-assembled the rad to re-start the car. The Noise was gone! (but now I began noticing a strange 'squeeking' sound... oh well). At least now I know the clutch is the culprit (of the original 'strange noise' at least
I'll wrap it up once my fan clutch arrives.
WAQAS in Austin, Texas
