Author Topic: 5 speed tranny  (Read 3725 times)
Franz W
5 speed tranny
« on: August 22, 2006, 03:30:16 »
Hallo,
i was reading a thread in this forum about a 5 speed ZF transmission, which was sold in June in ebay.
Somebody wrote, that the bell housing of this transmission was made of aluminium and not of cast iron, and that it is hard to find a bell housing.
My question is: Are there different bell housings for 5-speed and 4-speed transmissions ?
I thought, it is always the same bell housing, not depending on what transmission is used.
Franz
Re: 5 speed tranny
« Reply #1 on: August 22, 2006, 10:59:38 »
The 5 speed bell housing is made by ZF and is sand cast aluminum. All MB ( pasenger car ) bell housings are made of aluminum and the newer ones are die castings.
Franz W
Re: 5 speed tranny
« Reply #2 on: August 24, 2006, 00:24:30 »
Hallo Benz Dr.,
so is it possible to fit a 5 speed ZF gearbox to the bell housing of a mercedes 4 speed transmission ?
best regards Franz
Vince Canepa
Re: 5 speed tranny
« Reply #3 on: August 25, 2006, 05:09:59 »
I doubt it.  The bell housing on the M-B transmission does double duty as the bearing cover for the main and countershaft bearings.  The recesses in the bell housing are of a specific depth to accomodate this.  It would be unlikely that ZF would use exactly the same dimensions.
Vince Canepa
113.043-10-001543
568H Signal Red
116 Caviar MB-Tex
