Author Topic: Ball Joint Removal Tool - Recommendations?  (Read 3453 times)
rogerh113
  • Los Altos, Ca
« on: September 12, 2006, 13:19:44 »
I need to rebuild my steering relay/idler arm, and to do so I need to remove the 2 ball joints attached to it.  I have an old 'pickle fork' which I don't want to use because the ball joints (and rubber covers) and in good shape and I want to keep them that way.  I have seen some of the lever type ball joint separators (like OTC), and would like to know if anyone has used these with success, and any suggestions as to brand to get.
Thanks -- Roger
merrill
Re: Ball Joint Removal Tool - Recommendations?
« Reply #1 on: September 12, 2006, 13:37:22 »
try http://www.samstagsales.com/mercedes.htm
they may have the correct tool you need
Matt
66 230 sl - "white"
78 300 D - Blue
98 C230
Matt
Austin Tx
66 230 sl - "white"
78 300 D - Blue
98 C230
knirk
« Reply #2 on: September 13, 2006, 02:45:53 »
Roger,
Have you tried the universal balljoint separation method: Unscrew the nut, but not completely – leave it on for bolt protection. Then, with a heavy hammer give the side of the hole just above/below the balljoint some good blows. Do not try to bang on the bolt it self!
Somebody may think that this is a too violent method on our beloved cars, but it works for me…
Per G. Birkeland
69 280 sl aut 834
Norway
