Author Topic: 280SE 4.5 axle documentation  (Read 3025 times)
« on: September 19, 2006, 13:08:09 »
Bought a 3,27 axle with the intention of installing it on my 280SL.  Delivery in October.  I'm told it may be a limited slip differential.  Does anyone know where I can find any maintenance/repair documents on the axle.
Thank you,
« Last Edit: September 20, 2006, 06:19:14 by jeffc280sl »
Re: 280SE 4.5 axle documentation
« Reply #1 on: September 22, 2006, 09:05:40 »
Other than the tag on a LSD indicating the need for a particular oil is there any other exterior indication on an axle to indicate that it is or is not a LSD version?  I know about the gear ratio stamping on the differential.  Are there any part markings on a 280SE 4.5 axle?  If so where can I find them?
Many thanks,
lurtch
  • USA, CA, Santa Rosa
  • " ICON 66 "
« Reply #2 on: September 22, 2006, 10:36:02 »
Hello Jeff - - -  I have no knowledge about the LSD option, However, I can assure you you are really going to be amazed by the improved cruise performance with the higher gear rear end. I was pleasantly surprised when I discovered that a previous owner had installed a 3.27 in my car.  The photo shows how inaccurate your speedo will be if you do not modify it ( I have not done mine yet ). Your road speed will be 1.15 times your indicated speed.
Regards, Larry
Download Attachment: 3400-RPMs-equal-70-MPH.jpg
20.45 KB
Larry Hemstreet  in  N. Cal.
1982  300TD-T (parted out)
1986  560SEC (totaled)
1991  300TE (gifted)
1998  E320 (sold)
2004  E320 wagon (gifted)
2008  CLK550 Cabriolet
« Reply #3 on: September 22, 2006, 13:15:45 »
Larry,
I thought California freeways were terribly congested!  I'll never believe the hype from now on.
