Author Topic: wheel colour  (Read 5431 times)
wheel colour
« on: September 19, 2006, 20:13:42 »
I came across a nice example on ebay (item number 260031017594).
I'm wondering: isn't the wheel supposed to be body colour, and the hub-cap centre supposed to be the same colour as the hard-top?
This example's wheel painted black (or something like it) gives the car a very stylish look and I'm wondering if it can also be called original?
Personally, in this case I would still make the hub-cap centres the same colour as the hard-top. Comments?
WAQAS in Austin, Texas
« Last Edit: September 21, 2006, 10:13:13 by waqas »
Re: wheel colour
« Reply #1 on: September 19, 2006, 20:17:07 »
In case you're wondering, my wheels are due for a repaint, and this particular combination has sparked my imagination. I currently have the one-piece hub-caps, and I've been meaning to revert to the original two-piece version that my 230sl probably came with.
Re: wheel colour
« Reply #2 on: September 19, 2006, 20:54:55 »
Hey Waqas. A while back I did a poll here because I was considering re-painting my black wheels back to bodycolor (which is white). Most here felt white would be correct. However, one response was "keep them black" because it adds depth to the wheel. I agree and that's why I have kept mine black...That may be what you like about this example...
P.S. My wheel centers are dark blue to match my dark blue hardtop. I think you are correct that this guy's centers should also be black.
« Last Edit: September 19, 2006, 21:25:21 by J. Huber »
Re: wheel colour
« Reply #3 on: September 20, 2006, 09:29:30 »
Hi James,
That clinches it for me. Thanks for the reply!
joelj
Re: wheel colour
« Reply #4 on: September 20, 2006, 10:54:39 »
I have two sets of hub caps. If i have the top down, I use my white hubcaps which is the body color of my pagoda. when my dark blue hard top is on, I use the dark blue hub caps :)
cheers
joel
1969 280sl auto
White exterior
Blue interior
Cortez-Campos
Re: wheel colour
« Reply #5 on: September 20, 2006, 14:57:06 »
I think it is because the hub caps has been recromed.
I just got mine recromed, and it is very difficult to polish inside the hupcap, so I was recommended to paint the inside of the hup cap too.
Christian Cortéz-Campos
280 SL 1969 anthracite 172, with red inteior.
Re: wheel colour
« Reply #6 on: September 20, 2006, 16:43:13 »
Hello Christian - out of curiosity, what was the reason for getting your hubcaps rechromed rather than getting new ones? I suppose rechroming means they are the original ones (brass?) vs new ones would be polished stainless steel? Would the cost of rechroming be higher than buying new ones?
Cortez-Campos
Re: wheel colour
« Reply #7 on: September 21, 2006, 05:21:12 »
Hi Cees, I don't know if mine is brass, I just gave my bumpers, hupcaps and frontgrille ( stars and wings ) to a company, I bought a new frame.
I paid ca. 900 dollars for the recrome in total, and I think ca. 30 dollars pr. hupcap, but the hupcaps are not nice done, due to that they are difficult to polish.
So I will exchange them for some new ones at pagodenteile.de, as I remember they cost 49 Euros pr. hub caps.
merrill
Re: wheel colour
« Reply #8 on: September 21, 2006, 07:09:47 »
Waqas,
I need to have mine stripped and painted as well.  maybe we can work out a discount with the shop?
I was just going to strip them myself and then use a single stage paint to paint them.  the trick would be to see if napa can match the correct paint.
If not, I have the old steel rims from my 78 300d.  would these work on a 230 sl?
Matt
Matt
66 230 sl - "white"
78 300 D - Blue
98 C230
Matt
Austin Tx
66 230 sl - "white"
78 300 D - Blue
98 C230
merrill
Re: wheel colour
« Reply #9 on: September 21, 2006, 07:10:24 »
Waqas,
Matt
Matt
66 230 sl - "white"
78 300 D - Blue
98 C230
Matt
Austin Tx
66 230 sl - "white"
78 300 D - Blue
98 C230
Re: wheel colour
« Reply #10 on: September 21, 2006, 08:27:42 »
So I am a little confused. Waqas, are you considering painting the wheels or the wheel covers? and Merrill, which are you thinking of painting?
Re: wheel colour
« Reply #11 on: September 21, 2006, 10:06:51 »
James,
To clarify (I'm reclaiming that word back from our commander-in-chief): I'd like to repaint the wheel rims, on which the tyre is mounted. I currently have the one-piece [chromed] hub-caps, and I'd eventually like to switch to the two-piece type. The wheel rim colour only shows through the two-piece type.
Re: wheel colour
« Reply #12 on: September 21, 2006, 10:11:09 »
Matt,
Not a problem. I still haven't acquired the two-piece hub-caps, so it may be a little while. One of these days, we need to get together for the first Austin Pagoda SL Group meeting...  8)
merrill
Re: wheel colour
« Reply #13 on: September 21, 2006, 10:17:56 »
Waqas,
no problem, been working on the car for 2 years anyway.
matt
Matt
66 230 sl - "white"
78 300 D - Blue
98 C230
Matt
Austin Tx
66 230 sl - "white"
78 300 D - Blue
98 C230
Re: wheel colour
« Reply #14 on: September 21, 2006, 11:59:52 »
Thanks Waqas, that's what I thought we were talking about!
