Author Topic: 3,27 axle checkout, reseal, repair & install  (Read 72183 times)
Re: 3,27 axle checkout, reseal, repair & install
« Reply #101 on: June 09, 2008, 10:44:07 »
Hello Jim,
The 3.75 gear was also used on the 220SEb coupes.
JimVillers
  • USA, VA, Virginia Beach
« Reply #102 on: June 10, 2008, 19:04:55 »
Joe .... I feel almost like I am cheating.  I located an entire 3.75 230SL rear axle complete with brakes (the aluminum drums are worth almost the cost of the rear axle).  My plan is to install new seals, boot and axle bearings before installing it.  It should be an easy swap and drop my RPM by 10%.  Not as desirable as a 3.27, but in the right direction.
Jim Villers
« Reply #103 on: June 10, 2008, 21:19:36 »
Hello Jim,
Yes those expensive finned aluminum drums are the same as in your 190SL also!
« Reply #104 on: September 03, 2008, 00:11:59 »
Originally posted by babak
Well it drives much nicer than before .I drove to paradise cove in Malibu on sunday and what a great change man. Lower rpm and we can hear the radio much better too. By the way 1 thing that did not fit was the emergency brake cables because mine was drum brakes ....
Hello Babak,
since you mentioned drum brakes, do you have a 230SL??  If so what exactly was swapped?
I am thinking of installing a 3.27axle in my 230SL and it appears that you may be the only one here who did this! 8)
Thanks.
