Author Topic: radiator hose question  (Read 2658 times)
merrill
« on: October 07, 2006, 14:18:15 »
I am in the process of replacing all the hoses in my 230 sl.
I am having trouble getting the short hose between the thermostat housing and the water pump body off.
do I need to remove the thermostat housing to get this off?  If so, it appears there are only 2 bolts holding the housing on
is this correct?
thanks in adavance
matt
Matt
66 230 sl - "white"
78 300 D - Blue
98 C230
Matt
Austin Tx
66 230 sl - "white"
78 300 D - Blue
98 C230
Re: radiator hose question
« Reply #1 on: October 07, 2006, 14:55:31 »
Matt,
I replaced mine.  I cut the old one off.  To install the new one, I sprayed it with some silicon spray and sort of bent it, while slipping it on.  Not easy, but this worked for me.
Good Luck!
merrill
« Reply #2 on: October 07, 2006, 19:33:34 »
hmm, thanks for the response,  i guess I should have waited.
while trying to get the hose off, I unbolted the housing from the motor and ever so slightly separated the housing from the motor.
I wonder if I should get a new gasket for mounting the housing to the motor before I install the new hose?
thoughts?
matt
Matt
66 230 sl - "white"
78 300 D - Blue
98 C230
Matt
Austin Tx
66 230 sl - "white"
78 300 D - Blue
98 C230
« Reply #3 on: October 09, 2006, 06:34:10 »
Sounds like a good assumption.
