Author Topic: Cold Air  (Read 2267 times)
Roman Kishi
  • USA, VA, Fairfax
Cold Air
« on: October 15, 2006, 08:43:14 »
It started lately do get little chilly here in Northern Virginia . Yesterday, and to my surprise I found out that the air that's coming from the vents is not warm enough. Heater levers are new and working beautifully, the heater blower is blowing air nicely, and was blowing nice hot air last spring....!!!!
Does this mean I have to go through the dreaded heater core removal job, or is there another possibility???
Roman
Northern Virginia
280 1969,Signal Red, Auto
Roman
Northern Virginia
George Des
Re: Cold Air
« Reply #1 on: October 15, 2006, 09:01:49 »
Roman,
Ck the two hoses going into the firwall. If the heater is on, they should both be hot. If not, it's time to check the hot water valve linkage connection under that rubber seal on the firewall. Lots of posts on how to fix if this is the culprit.
George Des
Re: Cold Air
« Reply #2 on: October 15, 2006, 09:11:22 »
Make sure your engine is getting up to operating temp.  When I bought mine, it would actually run too cool and the heater didn't work well.  I believe the thermostat was stuck open because after changing that (and back flushing coolant) the engine ran warm and the heater works great.
