It is 36mm, and I'm probably that 'someone' who said it was 36mm in my thread on changing those bushings. I used a 1" drive, which you'll know if you read my thread. It maybe that the size of the drive meant that the socket was so large I had to cut it. Note that on the 230 at least the clearances are different on each side.
Good luck.
JH
