Author Topic: NEED HELP W/ TRANI #  (Read 3956 times)
BABAK
  • USA, CA, Valencia
« on: October 23, 2006, 23:42:35 »
CAN ANYONE TELL ME WHAT MERCEDES YEAR AND MODEL TRANI THIS IS? iM HAVING A HARD TIME GETTING THE RIGHT CLUTCH KIT FOR THIS. I DO HAVE A 64 230SL THE NUMBERS DONT MATCH .motor # 130 980-10-016465 .I KNOW NOW 280SE 68 TO 71.THE CLUTCH KIT I ORDERED HAS MATCHING PRESSURE PLATE and disc but the bearing IS TOO SMALL ON THE NEW ONE javascript:insertsmilie(' 8) ')
Cool  8)
THANK YOU A MILLION FOR ALL THIS EVERY ONE
and now i need help with trani #
111 281 0501 (on top)
10 7 62 on (side)
69 280sl dark olive automatic
71 280sl bronze brown
70 280se coupe light Ivory
59 190sl
61 190sl
www.vintageeuroparts.com
Re: NEED HELP W/ TRANI #
« Reply #1 on: October 24, 2006, 03:36:07 »
I would guess its from a 280SE sedan W108 chassis, as I think the 280SL motors are 130 983 !
It will fit however !
Klaus
« Reply #2 on: October 24, 2006, 08:19:35 »
Ben is correct; additionally it was used in the W111 280 SE Coupe and convertible.
Production W 108 with 130.980 from 11/67 to 9/72
Production W 111 with 130.980 from 11/67 to 5/71
Klaus
1969 280 SL
« Reply #3 on: October 24, 2006, 13:54:12 »
Originally posted by babak
.... WHAT YEAR AND MODEL ....
Model has been answered, but year might be more difficult.  It might not matter, though, as when the time comes to order parts, you just give the engine number so the parts supplier knows what you need.
« Reply #4 on: October 24, 2006, 14:37:23 »
Additionally, the '10' denotes a standard (manual) transmission block, whereas a '12' would be an automatic.
Abbas
« Reply #5 on: October 25, 2006, 12:45:36 »
Check this link with references to all
MB US models including chassis and
matching engine numbers.
http://home.hiwaay.net/~gbf/mbmodels.html
W108.018 M130.980 I6 280SE 1968-72
W108.019 M130.980 I6 280SEL 1968-72
W111.024 M130.980 280SE Coupe 67-71
W111.025 M130.980 280SE Cabriolet 67-71
I6 stands for injection 6 cylinders
Abbas
280SL W113 1969 Ivory
E280 W124 1995 Silver
« Reply #6 on: October 25, 2006, 19:15:46 »
It may also stand for In-line 6 cylinders.  As apposed to V6.
« Reply #7 on: November 07, 2006, 04:13:00 »
Babak,
but the disc and bearing IS TOO SMALL ON THE NEW ONE
Have you got the numbers from your old disc and bearing, or pictures  :?:
« Last Edit: November 07, 2006, 04:14:09 by naj »
