Author Topic: Top Latch on Hard/Softtop is loose  (Read 2917 times)
vincesy
« on: October 27, 2006, 17:40:31 »
Does anyone have problems with the hardtop's top latch coming loose during driving?  I have this problem even with the soft top.  I'm wondering if there's an easy way to fix or adjust this.  Thanks.
Re: Top Latch on Hard/Softtop is loose
« Reply #1 on: October 27, 2006, 19:11:19 »
It's possible that the rubber washers that sit around the locking pins need to be replaced.  I replaced mine and it has made the softop and hardtop tighter against the windshield.  Easy to replace!
vincesy
« Reply #2 on: October 30, 2006, 00:50:33 »
Bob, thanks for the advice.  Is it something that one can just fish out and replace with new washers?  I don't see washers around the locking pins.  Maybe that's why I have this problem?
« Reply #3 on: October 30, 2006, 06:22:24 »
SLS carries these hard rubber washers.  They simply slide over the locking pins (no glue) on both the hard top and soft top.  They are a very tight fit, stretching a bit while sliding over the pin.
Click on this link and scroll down to the softtop page.  Refer to item #43 (Buffer ring on lock)
http://213.239.220.84/bin/dbframes.phtml?mid=IN02
« Last Edit: October 30, 2006, 06:24:51 by bpossel »
vincesy
« Reply #4 on: November 05, 2006, 16:15:48 »
Thanks for the advice.  I've ordered the rubber washers and hopefully this cheap and easy solution does it.  I don't even know how long the car has been without these washers.
Vincent
