Author Topic: late gear change  (Read 2747 times)
nick350
late gear change
« on: October 29, 2006, 14:23:40 »
I have had an exchange gearbox fitted and it sort of seems OK other than that now I have to get to about 45 mph before it finally changes into 4th then of course if I slow down it slips into 3rd too soon. I never seem to be in the appropriate gear. It was quite smooth until recently. Any ideas?
Re: late gear change
« Reply #1 on: October 29, 2006, 15:24:18 »
There is a (modulator valve?) pressure setting that, as far as I know, affects the shift points. Have you tried the search function on this site yet? There could also be relevant information here: http://www.sl113.org/articles/default.asp
The ignition timing also affects the vacuum that helps to regulate the transmission shift points, but I am assuming the ignition was not altered when the transmission was swapped out, so 'technically speaking' (that's a pun I believe) it should not be a factor in your situation?
1972 Lancia Fulvia Coupe 1.3
« Reply #2 on: October 29, 2006, 20:07:05 »
Hello Nick,
These people have given a very nice write-up on the initial set up of these units. Take a look! http://www.mercedesdismantlers.com/16BoltInstallationInstructions.html
