Author Topic: Lock your glovebox!  (Read 7241 times)
Lock your glovebox!
« on: August 07, 2003, 11:51:52 »
Check out the price of a pair of top removal handles at this website:
http://oursl.com/parts-230-250-280.htm
YIKES!
Re: Lock your glovebox!
« Reply #1 on: August 07, 2003, 12:05:05 »
Doug posted that to scare us.
I have seen original handles in the original case go for about the same $400 plus range on eBay...
It's good to know that a top handle for "everyday" use (repro, works very well) is about $30; and a modern repro plastic holder for two tools is about $30.
Richard M
bayleif
« Reply #2 on: August 07, 2003, 12:32:47 »
This brings to mind a survey type question. Do you remove your handles each time you raise and lower your soft top or do you tighten the set screws and leave the handles in the top until it's time to put on the hard top?
Personally, I got tired of taking them on and off and so I leave them on.
Chuck Bartlett
Chuck Bartlett
1969 Signal Red 4 Speed
« Reply #3 on: August 07, 2003, 13:12:59 »
Chuck:
"...tighten the set screws..."
This is news to me. Where are the "set screws"? If tightened do the screws keep the handles in place?
Richard M
LFrank
« Reply #4 on: August 07, 2003, 13:48:59 »
I've got a 230, so my handles are "in place" all the time...why did Mercedes change that set up?
LFrank
Washington DC
65 230 sl
DB334/Hellblau
« Reply #5 on: August 07, 2003, 14:58:52 »
The reason for the change from fixed handles that is heard most often is for safety reasons and to comply with US regulators who wanted all potential hazards removed from the interior....so the fixed top handles went, the door pockets became soft sided, sun visor mirrors were either removed or covered, wipers lost their high shine, etc...
Richard M
bayleif
« Reply #6 on: August 08, 2003, 13:35:24 »
Frank,
It's difficult to describe, especially when the car is at home and I'm at work. But each of my handles has a small slotted screw which when tightened down keeps the handle from coming off. Doesn't everybody's?
B.T.W. when I looked at my first 280SL that had the soft top up, I thought that the handles had been broken off. No mater, I wouldn't have bought that car even if I had known that the handles were supposed to look like that.
Chuck Bartlett
Longtooth
« Reply #7 on: August 12, 2003, 01:06:30 »
Does anybody know when the handles became removable... i.e. what series, what Chassis number?  I like my fixed handles on my '67 250SL, but if I want to buy a 280SL (say '68) did they change the handles to removable type with the 1st 280SL's? or what?
Longtooth
95 SL500
Albert-230SL
« Reply #8 on: August 12, 2003, 04:24:06 »
Longtooth
95 SL500
According to the MB Spare Parts Catalog for W113, it seems that removable handles were introduced in 250 SL from VIN 005089.
280 SL from 000007 up to 012192 had that same removable handles, and 280 SL from 012193 had a second type (much cheaper!) of removable handles.
So, maybe only 280 SL from 000001 up to 000006 had fixed handles... :?:   It will be a difficult hunt!
Albert de la Torre Chavalera
Barcelona (Catalunya/Spain)
« Last Edit: August 12, 2003, 04:27:46 by Albert-230SL »
Longtooth
« Reply #9 on: August 12, 2003, 19:54:18 »
Albert, thanks... I don't have my spare parts catalogue yet... guess I'm going to be SOL then in searching for a 280SL with fixed handles, huh?!  Many honest thanks... you've saved me worrying about it now.
Longtooth
95 SL500
« Reply #10 on: August 13, 2003, 08:32:28 »
Just put an older soft top frame on the car.  The holes in the windshield header should be the same, right?
1966 230SL Euro
« Reply #11 on: August 13, 2003, 21:38:55 »
Yes, I can confirm that a 230 SL soft top frame fits perfectly in a 280 SL.
