Author Topic: Window Guide Jaw Replacements  (Read 3254 times)
AGT
« on: November 05, 2006, 11:52:19 »
I had trouble with my  door windows this last summer and am planning to work on them over the winter.
I have read the posts on the Bud's Benz felt guide jaw replacements. Can anyone explain where these are fitted? Any views as to whether they are  effective and worth incorporating as part of a window re-furb?
Regards
Andrew
Andrew
1966 230SL
Re: Window Guide Jaw Replacements
« Reply #1 on: November 05, 2006, 12:12:16 »
I have installed the Bud's window guides and like them.  Over the years I have epoxied the jaws on my windows only to have them fall off a year or to later.  The felt covered U channel from Bud's is nothing special.  It can be found elsewhere.  Check under window channel.  The U channel needs to be glued into the same location your window jaw uses.  If you remove your door panel and look to see where the front and rear edges of the window ride this is where you will want to glue the U shaped channel.  At present the front and rear edges of the window glass are fastened to the guide jaws.  Imagine the jaws removed and the window sliding up and down in a felt U channel in the same location.
sterl
« Reply #2 on: November 05, 2006, 12:46:27 »
I've just fitted them to my windows and they work fine. I used them because two jaws had fallen off (one of them was missing). If you're replacing the felts along the top of the metal part of the door too, you won't have to notch them to clear the jaws (one of the benefits). The downside to these new channels is the price. Bud's sent them UPS to me here in the UK and it was $89 on top of the price of the parts! To add insult to injury I had to pay customs charges of another £24 (yes, pounds) when they arrived. I rang Bud's and complained that they'd obviously made a mistake but they were adamant that the price was right. If you buy them, try to get US Postal. Takes a bit longer but much cheaper. I've bought a few parts from the USA recently and sellers like the traceability of UPS parcels. I'd rather wait a few more days than pay those kind of prices. Rip off if you ask me.
Anyway, the bits I got from Bud's are metal with a material and felt-like covering. Their construction seems very durable. No idea where you'd get something similar over here.
Be careful when removing the old jaws. I took out the retaining screws and soaked the jaws in penetrating oil overnight so they were easier to remove.
Mark
Billericay, Essex, UK
Late 67 LHD 250SL
