Originally posted by dngalura
Maybe it's more blue's than white. I will monitor my oil consumption. If this so, what to do?
Dan,
It depends. Find this information:
- How many miles are on the engine?
- What is the rate of oil consumption (1 quart per XXX miles)?
- What is the compression of each cylinder?
- Does the compression info change using the "teaspoon of oil in on the piston" test? (Probably wrong definition of test.)
- What is the leak down test results?
RoddPowell, Ohio, USA
1966 230SL, Euro, Auto, Leather, both tops
